Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
Interferes with my dsl
I am trying to get this phone to work! When I go online my phone is not able to detect that I am online, It has a busy signal like I have left the phone off the hook. My old phone does not have this problem, when I plug it in it works just fine, and I can be on the phone and internet at the same time, DSL. I bought this new phone because the old one is falling apart. This phone is a Vtech 5.8 model # IA5870. It is a two set phone with caller ID & answering machine. How can I fix this problem? Please help!!! I can't find the manual and threw the box away months ago.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
You can download the manual from the manufacturer's web site at
Posted on Jul 19, 2010
Can canon mf4370 fax on dsl line
Fax machine operation can be interrupted by DSL lines, however, because the DSL signal is also transmitted through phone wiring. This can result in a loss of data in the fax if steps are not taken to prevent it. Fortunately, this is not a difficult thing to fix.
Items you will need
  • DSL filter
Step 1
Unplug the fax machine from the phone jack.
Step 2
Plug your DSL filter into the phone jack. DSL filters are specifically designed to eliminate interference from the DSL line on your phone line.
Step 3
Plug the fax machine into the phone line jack on the DSL filter. You can now use your fax machine and DSL line at the same time without risk of data loss or interference.
Feb 05, 2013 | Canon ImageCLASS MF4370dn Laser All-in-One...
How can i get my phone not to kick my wifi off?
Are you using DSL? It sounds like you dont have filters on all of your phones. Each phone that is plugged into a phone jack needs a DSL filter on it, as well as the DSL; It needs to be plugged into a filter as well. You should be able to get these from your phone company or broadband provider. When you are online and your phone rings, the phone signal will cause interference with the DSL signal and cause it to drop.
Jan 27, 2011 | NetGear WGR614 Router
My brother wont fax it says Poor line conection (good conection phone works) out of memory
Do you have DSL? If so make sure you have a DSL filter on the line to the fax otherwise the DSL signal will interfere with the fax data signal. The DSL signal might not perceptively interfere with voice transmission (though it is likely that it would) but will definitely interfere with data transmission from the fax.
Nov 01, 2010 | Computers & Internet
My cordless phones crackle
Do you know what frequency the phones operate on? Many devices can interfere with cordless phone signals, including wireless routers, Bluetooth devices, and even microwaves.
Try moving the phones away from any of these devices and see if that helps. If you use DSL for your Internet service, make sure you have placed filters on all of the phone lines that don't go to the DSL modem.
Aug 09, 2010 | AT&T 650530003417 Cordless Phone
Brother Inellifax 4100e will not send
It appears that you have interference somewhere in the office. Have you recently gone to DSL in the office? A DSL line transmits a signal that requires a filter to receive only phone signals instead of the DSL signal. If the fax machines are receiving an unfiltered DSL signal, this would explain the interference. If this is not the case, the link below is a Brother's Solution to the NG Poor line quality. Best of luck to you with your fax problem.
May 12, 2009 | Brother IntelliFAX 4100 Laser Fax
My phone has been out for some time. Just noise on my phone. the outside plug in works fine, so I assume it is my inside wiring. This morning I unplugged all my phones, and hooked them up one by one. ...
Replace the DSL filter. it is needed to in order to prevent interference between phones and DSL service operating on the same line. Without the installation of DSL filters, high-frequency signals or echoes from analog devices can result in reduced performance and connection problems with DSL service, and the high-frequency signals from the DSL service can result in line noise and other issues for analog devices.
Aug 20, 2008 | Lands Phones
No dial tones on all the phones.internet still works. when you dial the house, phone line has busy signal.
If you have dial up internet, turn off your computer and try it. If you have DSL then a wire has come loose at your phone box. There are 4 wires that come into your house from the phone connection. Phones use 2 of them and DSL uses the other 2.
Jul 12, 2008 | Lands Phones
DSL line. Possible that filters are not plugged in. When DSL service is being used on your line, filters must be installed at every jack that is in use. The DSL signal can cause static/noise, squealing (similar to fax tones) and other issues on your line. (ex. Caller ID problems). In order to avoid having this issue, the service provider gives DSL filters to all customers when they sign up for service. These microfilters must be used because they allow your phones to work properly by blocking the high frequency DSL signals from being transmitted through the telephones. DSL filters should be plugged into EVERY phone jack that has a phone. If you are not using the filters provided by the telephone company, this will cause static/noise and possibly Caller ID issues on your phones that are plugged into jacks without filters. Please contact your service provider for filter information and proper installation. Interference: Other 2.4 GHz products. Other products that use the 2.4 GHz band can interfere with the use of this phone. Items include: Radio towers, pager towers, cell phones, other 2.4GHz cordless phones and 2.4 GHz intercoms or monitors. If any of these items are in the area, they can interfere with the performance of this phone; try relocating the phone. Other 5.8 GHz products. Other products that use the 5.8 GHz band such as home networking (wireless modems) other 5.8 GHz cordless products (phones etc.) can interfere with the use of this phone. Try relocating the phone. Interference from microwave. Microwaves work on the same frequencies as the 2.4 GHz phones. If the unit is on when the microwave is running, it is normal to experience static at that time. Do not plug this phone in the same outlet or near the microwave. Environmental. Normal radio operation. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, there is nothing wrong with the phone. Try channing channels. Surge protector or modem. Unplug modem or surge protector that is connected to the unit. Building structure limits range. Relocate telephone base near window when using telephone outside. Base unit located in basement or other low area. Relocate telephone base to higher location. The unit will get better reception if it is not located in a low area. Video displays, television sets and personal computers may cause interference. Video displays, television sets and personal computers can cause interference on this phone. Please relocate the phone to an AC outlet were there is no major appliance plugged in. If the base is near any of the above mentioned, locate the base to another room. Possible telephone line/service problem. Try using your equipment at a different location (i.e. friend or neighbors). If the unit functions properly in the new location, contact your local telephone company for assistance; additional charges to be incurred by customer may apply.
Feb 11, 2006 | Vtech VT 9152 Cordless Phone (VT-9152)
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
130 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
