Question about Brother LS-2125 Mechanical Sewing Machine
Top thread caught...
Perhaps I'm threading it wrong? But I've always threaded my machine this way and never had this issue...
I'm sewing right along.. and my top thread decided to go hide. I opened up my machine and my thread is being caught in the movable parts (looks like a screw-cog thingy- it's one of the parts you have to oil)
I haven't used it for awhile, so I took it apart, blew the dust out, and re-oiled it. I'm trying to sew but it keeps getting caught in this cog deal. >< I'm not into technical names or anything... so I don't know what it's called. But I'm wondering.. is my tension too low? because usually when the top thread runs away it means the tension is too high, so I lowered it, but it did the same thing? or is it possible I used too much oil? (a drop and a half, really?) Ideas?
  • iamtyping Aug 02, 2009
    Considering I hadn't used it for awhile, I opened everything up, cleaned everything out and re-oiled him (my machine is a guy, yes, don't judge.) before I started...
    I re-tried my project and he worked fine... for awhile. Then I moved to a different part I needed to sew and he freaked out on me again, only no thread breaks, it.. really I can't explain what happened besides the word "EVIL".
    I live in Texas, major humidity. Especially in the summertime. So I will definitely have to follow your advice there.
    My machine seems to be working fine now... and if he screws with me again, I'll have to get him serviced. (I don't have the money, really.) But anywho, THANK YOU -SO- much for the advice and everything. It helped quite a bit.
    God Bless,
    ~iamtyping
  • Brother Master
  • 1,388 Answers
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
Top thread caught... - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Aug 02, 2009
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
It says check for broken thread and the thread isn&#39;t broken
Pull both the top thread and the lower thread bobbin off. Check if there is thread caught in anywhere along the running mechanism, especially in the lower bobbin area. If there is no thread caught make sure the tension on the thread is not to tight.
Oct 01, 2014 | Baby Lock Esante
I have the Elna 320. The top thread is getting caught in the bobbin and creating a snarl. What's wrong?
probably the top thread is not under tension correctly, or the thread has not been placed into the take up lever, its generally a miss threading or lack of tension on the top thread that leads to it being pulled down into the bobbin area. Recheck your threading from scratch, always thread up the top with the presser foot raised as this opens up the top tension discs so the thread can properly seat into the tension device.
May 29, 2014 | Elna Sewing Machines
Bobbin thread loops on top
you are having trouble with thread tensions and that is causing your frustrations
find your self a good sewing circle and talk with the people who sew a lot and get some advice on how to set up the tension ( sewing machine repair shops can also help)
different tensions for different threads and needles --different needles ( eye hole size for different materials will require a thread tension adjustment
any thread that is over 6 months old is subject to breaking a lot as the material used to bind the fibres fails and the thread breaks easily
May 27, 2017 | Sewing Machines
Brother QS9050
Ok, by funky bobbin thread, do you mean the thread problem is on the underside of the fabric? That generally indicates a top thread issue.
I suspect this may be bird nesting or thread nesting, most often caused when the thread is not fully seated in the tension disk. This is probably the #1 reason I see with sewing machine issues.
Remove the top thread completely from the machine.
Install a brand new needle.
IMPORTANT! ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Retest the machine and tweak the tension, if needed.
Feb 25, 2018 | Sewing Machines
I cannot get the tension to set correctly on my Singer 6268 sewing machine. For instance, I'm using red thread on top spool and white in the bobbin. Suddenly, as it always does, the thread is loos
I have solved my tension problems by going to threadmagazine.com. they have solutions to many, many problems you have with your sewing machine. Hope this helps. jdokos95
Aug 01, 2012 | Sewing Machines
Sewing issues
try changing the needle
rethread the machine top--also make sure the presser foot is raised all the way up before you rethread the top
& bobbin--make sure it's turned the correct way
make sure the bobbin is not warped or damaged
keep a eye on the thread take up lever, because sometimes the
top thread comes off of it
May 31, 2012 | Kenmore Sewing Machines
HAVE A BROTHER XL5340 SEWING MACHINE WHEN THE TOP NEEDLE AND THREAD GOES IN TO LOWER BOBING IT WONT CATCH THE BOBING THREAD AND LOOP CORRECTLY ITS NOT CATCHING AND LOOPING AROUND THE BOBING
firstly check that the needle is in the right way, flat shank to the back. This is easy to get wrong and will prevent the rotary hook from catching the upper thread when the needle is at the lowest point in the stitch sequence.
Also check threading up of the top thread, particularly that the thread is through the take up lever.
There is good trouble shooting tips at http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Troubleshooting.htm too.
However, if you are certain threading up is correct, and needle is correct then the timing between needle and rotary hook may be out. There is diagrams at this website too for this problem
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm however, I've always left timing repair to my sewing machine technician to deal with.
Jul 26, 2011 | Brother XL-5340 Mechanical Sewing Machine
The tension on the top thread suddenly is too tight, could it be
Hi. That's always a possibility. Whenever you have problems like this, it's always a good idea to rethread the machine--including rethreading the bobbin. Another possibility is that lint could have gotten caught up in the tension disks. If you take a scrap of soft cloth and sorta floss it between the disks, anything caught up in there should come out. Brush out all the lint from the bobbin area, too, while you're at it.
Sometimes thread can slip out of the threading guides while you're sewing.
Hope this helps!
Robbie
Apr 16, 2010 | Necchi 3537 Mechanical Sewing Machine
My top thread gets caught in the bobbin. When I
Here are a couple of solutions to try.
* Try re-threading your machine. It may be threaded wrong.
* Raise your feed dogs
If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will prevent them from getting caught in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
105 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
