GW508K- water will not fill to correct level for machine to start..fitted new switch panel last night
    Scholar:
  • 76 Answers
When you say switch pannel, you do meen the pressure switch right? IS this the entire model number? i cant pull up any diagrams with these number. What brand and type washer is it. But it sounds like a bad pressure switch thought.
Posted on Jul 31, 2009
I have a fridgidaire laundry center model glet1142cso that will not fill completely with water.
You replaced the switch but did you check the hose to it for obstruction?
Mar 25, 2017 | Washing Machines
Electrolux evf 10240 do not heating. Everything else is OK. New heater is in machine. What is the problem?
Over temperature safety thermostat maybe open circuit if fitted temperature control thermostat or thermistor faulty ,water level sensor tube blocked so circuit does not switch on without water level correct. Lastly broken wire somewhere
Apr 12, 2014 | Washing Machines
My speedqueen top loader starts to fill up with water and every once in a while it overfills completely and overflows. It does not happen every time. Where can I check the switch /mechanism to stop...
There is a reset water level function on the front panel. To alter the water level each time you need to reset your water level . Ours used to do the same thing before my wife realized she was over filling it.
Jul 26, 2011 | Speed Queen Washing Machines
Top loader washer won't fill with water
Either the water level sensor is faulty or the selector switch is bad.
Servicing the Water Level Control Switch
This is another control panel switch, usually located next to the temperature switch. There is a small hose connected to this switch, and sometimes this hose becomes loose and falls off the connection. When this happens, the water in the tub usually overflows. To solve this problem, cut about 1/2 inch off the end of the hose and use a push fit to reconnect it to the switch.
The switch itself can also malfunction, resulting in tub overflow and other water-level trouble in the tub. If you suspect this switch is faulty, remove it by backing out the screws holding it in place. Take it to a professional service person for testing. If the switch is faulty, replace it with a new one of the same size and type. Connect the new switch the same way the old one was connected.
Oct 01, 2009 | Washing Machines
Kenmore 80 series wont stop filling up with water
There is an air line inside the machine... one side is attached to the outer tub... the other side is attached to the water level switch in the control panel... remove the face of the control panel, and see that the clear air hose is attached to that switch... if it's attached there then you'll need to remove the front panel and lid sections of the machine and check to see that it's attached to the tub... i've also seen on a few occasions the air line get clogged so if it is attached then disconnect one side and make sure you can blow through it... if it's attached at both ends and you get good airflow then the switch is bad... lemme know if you have more questions
Sep 24, 2009 | GE WBSR3140DW Top Load Washer
Washing machine overflowed
Try filling it again and stay with it, when it starts to get near the top, unplug it, if water continues coming out you need a new valve, if it stops, then the level switch inside the control panel is bad
Jun 17, 2009 | Washing Machines
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
The washer filled up with water and just started to tick, didn't spin, didn't wash. What should I do.
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
click the link
http://www.applianceaid.com/maytagwash.html
Nov 29, 2008 | Maytag PAV2300 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series heavy duty washing machine
Kenmore
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
Mar 01, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
