Question about Brother LS-2125 Mechanical Sewing Machine
Huge loops on back of fabric!
I have tried all the simple solutions (ie. tension knob, needle, thread, fabric change) but what I notice looking into the bobbin area is that the top thread is not being pulled in a full circle to complete the stitch. The top thread goes about 3/4 way around bobbin & then sags, creating huge loopy messy stitches and using a whole lotta thread. Using 2 diff colored threads, top & bottom, was helpful in this instance. Thanks.
So, is there something wrong with the metal spinning disc under the bobbin compartment??
  • Brother Master
  • 1,388 Answers
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
Huge loops on back of fabric! - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
bargainbox.com.au
Posted on Aug 02, 2009
My thread keeps looping on bottom Have changed tension, needle rethreaded and changed bobbin nothing helps what am I doing wrong?
not sure if this will help you...Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimesthread buching can be caused by something as simple as the tension dial being inadvertently turned.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC ? ' eBay
www.ebay.co.uk/gds/WHY-IS-THREAD-BUNCHING-UNDERNEATH-MY.../g.html..
or you could go to this link and see if it helps you out.. thread keeps looping Google Search
Oct 22, 2017 | Sewing Machines
Back side of stitches are loose
increase the thread tension of the needle thread
this is an indication that the tension is not enough to pull the bobbin thread up tight
Jun 15, 2016 | Sewing Machines
The bobbin thread when sewing has little loops
You do not have the tension on your machine set correctly. That is leaving the bobbin thread too loose, hence the loops you are seeing. What kind of machine do you have? I can tell you where the tension is located. Also, tell me what kind of fabric you are trying to sew. FIRST JUST SET IT BACK TO THE FACTORY DEFAULT. When you are moving the machine it is easy to accidentally hit the tension and change it. Here is a picture of what a tension knob looks like. Good luck.
Apr 24, 2016 | Sewing Machines
My sewing machine needle (very new one) keeps jamming every couple of turns of the needle - and the thread is very loose and loopy on the fabric. It makes a jarring noise
not quite sure how needle is jamming. I have had them break, had thread ball up underneath and caused needle to jam. Question is the needle in the right way, ie the flat side in as per manual, generally the flat side faces away from you. Sounds like your tension is not quite right if the thread is looping. Loops on bottom, bobbin tension, on top sewing machine tension
Dec 08, 2014 | Sewing Machines
HD 3000 loops underneath work
It's most likely not the machine. It's the other things, ie needle, thread, etc. combination. For sewing knit, be sure to use a ball point needle. The needle eye size is important to so the thread is neither too small nor too large for the thread weight.
FWIW, it sounds like bird nesting. --the thread is not seated completely in the tension disk. Remove the top thread from the machine and ALWAYS RAISE the presser foot when rethreading!
Also, check that the tension is appropriate for the project. The two threads should meet in the middle of the fabric. If there is top thread showing on the underside of the fabric, the top tension is too loose. Tighten it until it until the top thread pulls the bobbin thread up into the fabric.
All About Needles SCHMETZ Needles
Dec 04, 2017 | Janome Sewing Machines
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
Needle thread tension- huge loops
Put the tension settings back to the mfg's suggested setting.
Re-thread the machine with the presser foot up and there will be no more loops.
Mar 03, 2010 | Elna Sewing Machines
Have you changed the needle recently? It is possible you have a bad needle, or you need to change the needle as it is worn or bent. It is possible the needle is in backwards as well. It happens.
Jul 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
Fabric feeding, then jamming
If you are getting loops on the bottom side of your fabric then it is a TOP tension problem, usually the thread is not between the tension discs.
Here is a simple check: Thread the upper path and stop short of the eye of the needle. Drop the presser foot. Now if you pull on the thread you should feel the drag of the tension discs. Increasing the tension setting should make it harder to pull. Now while your pulling raise the presser foot. All tension should be gone and the thread will pull thru easily.
I have worked on a few Hello Kitty machines and usually there is a single screw to remove the nose cover, exposing the needle bar and slack arm assembly. The slack arm does just that, it takes up the loop and the tension discs keep it from pulling more thread off the spool. Look for some thread wrapped up in the mechanism and clear it if you can.
This is were I find most of the problems
Mar 29, 2017 | Janome Hello Kitty 11706 Mechanical Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
1,407 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
