Question about GE Profile JTP18 Electric Single Oven
F7 code displayed pushed clear/off button but resumes beeping cut circuit breaker to oven but did not help either
  • 725 Answers
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Sep 21, 2009
  • 42 Answers
Check www.repairclinic.com error codes
Posted on Aug 01, 2009
The General Electric under the counter oven is beeping and only stops when I push the Clear/Off button. Then it resumes beeping 1-2 minutes later. Also "F7" appears to the left of the time...
The F7 error code means that a key on the touchpad has shorted and the touchpad needs to be replaced... sometimes it's a electronic anaomily, since you have pushed Clear/off and the F7 returns it surly means that touchpad is bad.
GENE
Sep 09, 2011 | General Electric Ovens
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
What does F7 meanon my ge oven
The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
I hope this helps ,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | GE Ovens
Oven beeps and shows F7.
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
thanks.
Sep 29, 2010 | GE JGRP17 Gas Single Oven
I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
F7 stuck keypad
Jul 30, 2009 | GE JTP45 Electric Double Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Aug 08, 2008 | Kenmore 42161 / 42169 Electric Single Oven
JTO56
It's a common problem posted all over the internet. This solution works if you're willing to try it. Make sure you cut off power at the circuit breaker box in the garage.
http://www.fixya.com/howto/h155060-dreaded_f7_error
Apr 28, 2008 | GE Profile JTP56 Electric Double Oven
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Oct 08, 2007 | Ovens
GE Profile JTP18 Electric Single Oven Logo
726 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
