Question about ValuSoft Video Game Consoles & Games
Cannot open game , followed directions , went to Run at the start menu , typed in d;\setup and a pop up widow claimes it cannot find setup /file .
  • 114 Answers
Go to my computer, right click drive with game, click explore and look for an exe file.
Posted on Jul 31, 2009
How do i install a software for my computer.
Many software programs, games, and utilities have an AutoPlay feature that will automatically start the setup screen for the software program when the CD is placed in the computer. If your program, game, or utility contains this feature, run the installation through the screen that appears after inserting the disc.
If you are installing a program, game, or utility that does not contain this feature or you are installing a program from a floppy diskette, follow the below steps.
  1. Open My Computer.
  2. Within the My Computer window, open the drive that contains the installation files. For example, if the files are on a floppy diskette, open the A: drive. If they're on a CD or DVD open the D: drive or the letter of the disc drive.
  3. Within the drive that contains your files, locate either a setup or install file. Double-clicking on this file should start the installation for the program, game, or utility. If you see multiple setups or install files, try to locate the Application file or double-click each of setup or install files until you find the file that starts the installation. Many times the icons associated with the installation files have the same name.
An alternate method of starting the installation in Microsoft Windows
  1. Click Start and Run.
  2. In the Run Window, type x:\setup or x:\install where x is the letter of the drive you wish to start the installation from. For example, if you are attempting to install a program from the floppy disk drive you would type a:\setup or a:\install.
Any doubts you can get the help of a certified technician through the website:
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Sep 24, 2011 | Microsoft Windows XP Professional
Softwear Instalion
what problem are your experiencing?and what software are you trying to install?Please specify the problem and software so we can give you the solution//
Jun 27, 2011 | Computers & Internet
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
Cannot play games (example big fish games) after being downloaded to my pc. I get this message d3derr_notavailable
Your graphics card most likely doesn't support Direct 3D. You can test using the following command in a cmd prompt window dxdiag
In XP click start/run and type cmd in the run box to open a command prompt window.
In Vista/Win7 to open the command prompt, either go through the start menu - click start, All Programs, Accessories, then click on Command Prompt or in the run box type: cmd .
Dec 19, 2010 | Computers & Internet
I have windows 7. When i try to play Nancy Drew: Danger by design a box pops up requesting i insert disc 1. There is only one disc! It seems to work ok on windows xp. Ca you suggest anything to make it...
From the Nancy Drew web site:
Windows Vista/7 Support Installing older games (#1-13) with Windows Vista/7.
While our older games are not completely Windows Vista/7 compliant (notably games #1-13), there is a workaround which has been successful for most players. Please take the following steps to manually install.
If you had previously installed, uninstall the game and then delete all remaining game file folders from your computer, including emptying them out of your Recycle Bin. These files may be in one of the following locations:
C:\Nancy Drew\
C:\Program Files\Nancy Drew\
In your Documents folder: C:\Users\Username\Documents\
Once this is done, make sure you're logged on as an Administrator for your computer and manually install by taking the following steps:
1. Go to your "Documents" folder and create a new folder. Rename the folder with the title of the game.
2. Insert game Disk 1 in your disk drive and open "Computer" from the "Start" menu.
3. Double-click on your CD-Rom/DVD drive, look for a Setup or Setup Launcher Installshield file. Double-click this file to start the installation process.
4. When install asks what directory you want your game to install to, click "Browse".
5. Navigate to the game folder you created by selecting "C:" drive, then "Users" (or User name), then "Documents", then select the game folder.
6. Continue forward with the installation process, when asked if you want to install DirectX, check "No, I will install myself".
7. Upon completion, uncheck the "Play Now" box, click finish and exit setup.
For game titles #1-5, follow these three additional steps:
1. Right-click the game icon that is now on your desktop, select "Properties".
2. Under "Properties", click on the "Compatibility" tab.
3. Check the "Run in Compatibility Mode" box and then select "Windows 98/Me" from the drop-down menu.
You should now be able to open and play the game. If you installed an older version of DirectX with the game, please go to Microsoft's Download Center to download and install the latest version of DirectX for your version of Windows.
Aug 03, 2010 | Computers & Internet
Simple, step-by-step instructions on how to fix Error 1311 in Windows XP -- this error popped up when trying to repair/fix original installation of Microsoft Office 2003 -- not very computer savvy, but can...
Hello
Thank you for using
FixYa for your problem
To resolve this problem, copy the contents of the Office CD to a folder on your hard disk, and then run Office Setup from this folder. To do this, follow these steps:
  1. On your desktop, double-click My Computer.
  2. Double-click the local on which you want to create a new folder.
  3. On the File menu, point to New, and then click Folder.
  4. Type a name for the new folder, and then press ENTER. For example, type OfficeXPCD.
  5. Insert the Office CD into your CD-ROM or DVD-ROM drive. Hold down SHIFT as you insert the CD to prevent Setup from starting automatically.
  6. In My Computer, right-click the CD-ROM or DVD-ROM drive, and then click Explore.
  7. On the Edit menu, click Select All.
  8. On the Edit menu, click Copy.
  9. Right-click the folder that you created in step 3, and then click Paste.
  10. When all the files have been copied to the new folder, quit all other programs that are running, and then double-click Setup.exe in the folder that you created in step 3 to start Windows Installer and Office Setup.
  11. Follow the on-screen instructions to complete the Office installation.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Microsoft Windows XP Home Edition
No start up page just has screensaver
from the black widows screen, hit ctrl-alt-delete. This will bring up a menu. Choose task manager, the file...run. In the run box type restore. From the box that comes up choose rsttui.exe. This is the windows restore utility. Follow the steps to restore your system, choose a date from before the issue started happening.
May 26, 2009 | Acer Aspire One PC Notebook
Missing dll
When you start the computer, you see an error message similar to " S32evnt1.dll. An installable Virtual Device Driver failed DLL initialization."
Solution:
To fix the problem, edit the registry and restart the computer. Then update the Symevent files and restart the computer again.
Follow the directions for your version of Windows:
To edit the Windows XP registry
  1. On the Windows taskbar, click Start > Run.
  2. In the Run dialog box, type regedit
  3. Click OK.
  4. Go to the following key:
    HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlVirtualDeviceDrivers
  5. In the right pane, delete the VDD value.
  6. In the left pane, right-click the VirtualDeviceDrivers key, and then click New > Multi-String Value.
  7. Type VDD for the name of the new value.
  8. Exit the Registry Editor.
  9. Restart the computer.
To edit the Windows 2000 registry
  2. In the Run dialog box, type regedt32
  3. Click OK.
  6. On the Edit menu, click Add Value.
  7. In the Value Name box, type VDD.
  8. In the Data Type drop-down menu, click REG_MULTI_SZ, and then click OK.
  9. Exit the Registry Editor.
  10. Restart the computer.
To update the Symevent files
  1. Follow the directions in the document Updating the Symevent files.
  2. After you update the Symevent files, restart the computer.
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
Cannot install/uninstall Java
hi,
It is not necessary to install java in order to use java.
Just download java highest version, copy and paste the java software in the system drive(eg C:,D:,....), Then set path the java file.
Example, if you have the java file in your C drive, do the following steps
1. Goto start->Run-> type command. Command prompt(black screen) will open.
2. if it shows as C:> follow the steps, else Goto step 6.
3. set path="c:\Java file name"
4. type javac
5.after typing if u find compiler then Java is installed in your system.
6. Example... if it shows as F:> and if u have saved your file in C:, do the following.
7. cd..
8. cd..
9. cd C
10 .then it appears as C:>, follow from the step 3.
thank you.
May 07, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Video Game Consoles & Games Logo
849 people viewed this question
Top ValuSoft Video Game Consoles & Games Experts
James Wishart
MegaByteMe
MegaByteMe
Tom Chichester
Are you a ValuSoft Video Game Console and Game Expert? Answer questions, earn points and help others
