Question about Aloha Housewares (93645) Ceiling Fan
Fan remote does not work
The battery is fine in the remote controller, but the unit can not be controlled by the remote, the fan is keep running until I turn off the wall switch(but the light is off also), anyone can help?
  • Jeremy Spatrisano May 11, 2010
    Has it ever worked in the past? Let me know this first and then I can help you. There are tons of variables to consider when dealing with fans and the wireless remotes used to make them work.
    Sergeant:
    Champion:
  • 246 Answers
You need to carefully take your remote apart and clean ALL contact points including electronic board and the rubber pad contacts with a pencil eraser. After cleaning contacts with the eraser, blow out eraser dust and put remote back together. If there is no issue at the fan, your remote should be operational once again!
Posted on Jul 31, 2009
Remote control codes for a hampton universal video and fan remote?
First of all start with the basics, Hampton remotes will only work with Hampton fans. If you have a different brand of fan then you need to get the complete remote kit with receiver unit. If you open up your remote, you will see a place you can select a code configuration. This should be set identical to the code configuration of the fan. You may have to take off the cover of the fan to see the code. Or keep changing the code configuration in the remote, until it starts working.
Jan 10, 2015 | Universal Televison & Video
Fan with remote control speeds up on its own
bring the remote control to the store and have its function tested with similar unit. if the control works fine then you have no choice but to take down the fan and have it repaired
Oct 18, 2009 | Hunter 52" Ceiling Fan With Light And...
HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Sep 08, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Fan runs then stops light comes on when it wants to
if the unit is equiped with a remote controller, its possible the remote could be shorting out from within the case,try removing the remote batterys from the remote control. if this is not effective, try reversing the white & black wire from main house power, also you must use the groung line as this may effect the controller inside the fan assy.
nbcrca :)
Apr 11, 2009 | Hampton Bay 24002 Ceiling Fan
Fan and remote not working
If you haven't already done so, replace the remote's battery with a brand new one . Make sure the replacement battery is NEW AND UNUSED, AND WAS PURCHASED RECENTLY, SO IT IS FRESH. Make sure it is installed properly, making good electrical contact, and the proper polarity is observed. Was the remote dropped, sat on or stepped on? Was a liquid spilled on it? Did your pet chew on it? Are any of the buttons loose or stuck? If the remote seems ok, try removing 120 volt power from the fan by turning off the circuit breaker or fuse an your homes main electrical service box. Wait 30 seconds, then turn 120 volt power for the fan back on. This may reset the speed control in the fan unit. If it does not cure the problem, consult a professional electrician, or replace the fan, whichever is more cost-effective.
wait 30 seconds and turn 120
Jul 13, 2008 | Hampton Bay 24750 Huntington III Ceiling...
52 in. redington III cieling fan
Did you have to wire in the remote? If so you prob hooked up the light to constant power source. more info on number of wires on remote unit and wires on ceiling fan pls.
Dec 11, 2007 | Hunter 52" Ceiling Fan With Light And...
Remote control stopped working
Under the dome (where the electrical connections are) is the receiver unit for the fan. It could be that it is no longer working. Also the remote may have dip switches to change the frequency channel (sometimes located behind the batteries) check that these have not been changed or check they correspond to the receiver unit on the fan.
Jul 22, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Aloha Housewares (93645) Ceiling Fan Logo
283 people viewed this question
Top Aloha Housewares Dryers Experts
Mike Carew
Gene Haynes
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
