Question about Vivitek V37835 46 in. LCD Television
My remote springs are bent and the remote does not work at all. I've changed the batteries many times.  Where can i pruchase another remote?
    Problem Solver:
  • 15 Answers
Buy it from ebay. Just you need to google it from its model number
Posted on Aug 01, 2009
REMOTE WONT WORK
if its universal remote (replcement remote) it could just be that it needs code put back so it can communicate with TV. if its the remote that came with TV and has fresh batteries and does not work. I find most of the time its simple as the contacts in the battery area are not making proper connections cause they tend to loosen up over time. you will have to examine the battery compartment by opening up the remote. Remove batteries first and then attempt to open case with small flat head screw driver. Most them just snap together but some times there are screws. Be cautious when you do this not to break the case and remember reverse assembly order. When you get it open look for bent springs or clips in battery compartment.You might have to bend clip or pull spring to tighten up connections. If everything seem normal look for loose wire connection to battery terminals that are loose or not connected. if this is what it is then soldering iron & solder will do the trick. if all fails go to where you bought TV and ask for replacement because if its any thing more serious than battery connection then the remote has to be replaced.
Oct 09, 2012 | GPX Td2420Ab 24" 1080P Lcd HDTV - DVD...
Samsung BN59-00603A remote - flashing VCR button
1) clean the contacts batteries very well with contact cleaners
2) retight the spring contacts batteries with pliers for better contacts.
3) open the remote and clean the KEYpad with c.cleaner from oxide, corrosion, dirty, dust, and proof. The syscom must emit I.R very clean for work.
4) if after you did the before mentioned step, go to the repair shop TV for fix it.
God bless you
Sep 16, 2012 | Televison & Video
Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
Jul 02, 2012 | Hunter 27185 Remote Control
Hi My matsui tv 1409T remote died (due to battery leakage!) so I have got a signalex universal remote as a quick fix replacement. I have set the remote to switch the tv on/off, change channel and adjust...
1) Change the batteries by alkalines
2) Retight the springs contacts with plyer for better contacts.
3) clean the contacts with special spray contacts.
4) Downloa the code or proceed with your instruction manual.
5) If the problem persist, you must return you remote control and buy other from Radio Shack I am recommending.
God bless you
May 14, 2012 | Televison & Video
My Sony RM V301 remote control code for my panasonic tv/vcr combo isn't working i've tried 018, 016, 017, 007, 049, 067 are there any others?
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers
2) clean the batteries contacts
3) change new batteries
4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
God bless you
May 10, 2012 | Sony (RM-V301) Remote Control
Alba remote control not working
It is a standard spring. You can use and other one in place.
May 03, 2012 | Televison & Video
I've changed battery in isys+ pre amp on vintage vec500 and now tuner doesn't work (it is blinking green on note tuner no matter of tune and no note letters showing - blank screen)
Is the battery installed in correct polarity? If so- try rotate it in position to rub through potential corrosion.
Since it has a remote battery, it would not hurt to look at the installation to make sure no wires are broken. Especially the ground wire to the pickup.
It might also be a good idea to apply some contact cleaner to the output plug since it is in the power circuit. Cycle the plug in and out a few times to clean the contacts. Also some contact cleaner to the preamp controls would be useful.
Be aware some lubricants may contain silicone and that can interfere with wood finishes or repairs to the finish in the future.
Apr 06, 2012 | Music
I have tried programming my wii remote but it won't work. I pressed both the sync buttons, but all it does is flash on all 4 dots and then quits. I've changed the batteries in both remotes, as...
Here's what to do. I've had this happen many times.
1. Open up the SD Card compartment on the Wii.
2. Open up the battery cover on the remotes.
3. Press the red Sync button on the Wii, and then on one of the remotes.
4. Repeat for whatever remotes need synced.
This will make every remote act like the P1 remote. For temporary syncing, just go into the Home Menu and click Wii Remote Settings. Click on another option(it'll say to press 1 and 2) and follow the instructions.
Jul 19, 2011 | Nintendo Wii Remote Controller
Just change the battery on my Nike Anvil WC0020 watch and the alarm won't sound for the timer as well as the two alarm settings.
If you changed battery yourself, you've lost the tiny spring without noticing it. Carefully check around the place where you changed the battery. The spring itself is very, very tiny, so, be as concentrated as much as you can. That spring (coilspring named by watchmakers) transmits the signal from watch movement to the watch back cover where the sound membrane is located. In case if you find it, open the watch and insert that spring with the bent out end first in to the desired hole in watch movement (should be named COIL SPRING). After that re-assemble watch and the sound should work.
Jun 02, 2011 | Nike Mettle Anvil Super Watch Obsidian...
I can't get my remote to work (i changed the batteries). I now have satellite TV. I need to use the AV button on the remote in order to view DVDs. My satellite remote is no help. Do I need to order a new...
It's unusual for these remotes to break down, but they often suffer from bent contacts in the battery slot.
When the battery is inserted with the tray, if makes contact with a spring terminal on the main board, and a spring terminal at the back of the battery.
First check that the replacement battery is the correct type. If the replacement is too fat, then the board spring has probably been flattened, otherwise the back spring has probably been pushed in.
Either way, its quite easy to fix.
Board Spring: using a thin wire, such as a paperclip or precision screwdriver. gently lift the two contacts from the back until they stay up from the board.
Back spring: using the same tool, hook into the loop on the contact, and gently pull forward.
This will ensure that proper contact is made when the battery is inserted.
Don't worry if you pull the contacts too far, because the battery will push them back.
In this case, remove the battery tray
Mar 14, 2008 | Philips 26PF5320 26 in. LCD Television
Vivitek V37835 46 in. LCD Television Logo
59 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
