How much would it cost to fix my phillips plasma tv it only turns on in a warm enviroment and sometimes if you turn it on and off at switch.
    Sergeant:
  • 160 Answers
Sometimes, most of the time to repair a plasma / lcd flat screen the part to replace it, and then having someone fix it is going to be a good chunk of change. Several hundred dollars more than likely. Almost cheaper to just upgrade. Get a new one.
Posted on Jul 31, 2009
I Why won't my Phillips 42"plasma tv turn on?
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 26, 2015 | Televison & Video
I have a 10 year old Pioneer plasma TV (Pioneer PDP-R05E). When the TV is turned on, it starts with a black screen, and then some reddish dots flashing on the screen, mostly on the corners. After...
10 years on a plasma is pretty good. If you are losing the plasma screen, then it will not be worth the time/cost to replace. LCD TV's have come down (and the new 4K format is here) considerably, are less energy hogs and last longer than the Plasma (this can be debated on longevity but LCD technology has been around a long time and is more prevelant than plasma). Time to upgrade.
it could either be the screen (my bet) or the controller board for the screen. Either way, the cost to truck a repairman out there, diagnose, order the part and return could exceed what a new format LCD will run you.
Nov 24, 2014 | Pioneer Televison & Video
My Phillips flat screen model 42fd9935/17 has started going black after playing for about 2 hours... you can still hear the sound, but the screen is black... the picture will come back after turning the tv...
The cost of getting this plasma fixed is not costwise compared to getting a new TV. I recommend NOT to get another plasma but get either an LCD or LED for the best quality compared with price. Plasma parts can be quite expensive especially for a 10 year old model or may not be available.
Nov 03, 2011 | Philips 42FD9935/17 42 in. Plasma...
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
My phillips 42 inch plasma tv just clicks when I
There is no lamp in a Plasma TV screen and no ballast.
Check the power supply capacitors.
Aug 19, 2017 | Philips 42PFP5332D 42 in. Plasma...
My phillips plasma model: 42PF7320 will only work in warm places
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Aug 01, 2009 | Irwin Phillips Power Bit, #1 1 15/16"
My plasma tv has a red light flashing on the
You have to bad compacitors on the power board. They will be buldged on the top. Once replace you TV will live again. The parts will cost you about $4
Jul 25, 2009 | Philips Televison & Video
Our 52 inch Phillips Plasma tv is not working
open the back of the set and inspect the power supply board -- there should be two fuses on the board- they cost around 2 dollars at radio shack -- check all connections for wear or damage -- there are two boards in most televisions -- a power supply board and a audio / digital board -- one is probably board
Feb 28, 2009 | Philips 42PF7220A 42 in. Plasma Television
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips TV Sometimes Come's On No problem and Then Not sometimes with Green blinking light
I HAVE LOST THE TOP PORTION OF MY SCREEN, APPROX 2 1/2". IS THERE AN EASY WAY OF REPAIRING?
Oct 13, 2008 | Philips 32PT6441/37 32" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
