I used http://www.google.com and entered the words
Stratford Labs GFP-001 Slide Scanner
The results of my search identified two for sale cheaply on eBay.com
It may be easier to purchase one cheaply on eBay.com that include the CD than keep searching.
https://www.ebay.com/sch/i.html?_productid=6012042352&rt=nc&_pmc=true&_sop=15&isRefine=true&LH_ItemCondition=2750%7C1500%7C1750&sl_ready=true
SOURCE: i purchased a stratford labs
Just found the company that actually makes "Stratford Labs" scanners. Called them very helpful, still sending this one back. They actually answer the phone when you call, that's a plus.
1-847-550-9998 Affillated is the name of the company.
Stratford Labs GFP-001.
Dowadiddy
SOURCE: Lost installation CD
Well, I cannot help you with a disk, but I can offer this insight:
Seems this scanner only works with USB2 ports, and if you only have USB1 ports, you will not have any luck.
Additionally, while I cannot help you with drivers, I have found others who say that Windows XP (and it is assumed Vista) does not need drivers to operate this scanner.
Simply go to the Control Panel, (after it's plugged in to a USB2) and click on Scanners and Cameras. The operating system will guide you through a wizard which will allow you to scan images into your computer.
Once there, however, you are sort of on your own to choose the software you want to edit those images.
good luck
tony
SOURCE: I got a new computer with windows 7 and my old
look for windows 7 or vista drivers, or right click on program and try to install and use in compatability mode
SOURCE: Where can I get the
The manufacturer's website advises that the GFP-001 Image Scanner is, Compatible with Vista and Windows XP systems Only. Requires USB version 2.0 Only.
Sorry, but I do not believe you will be able to find support for Windows 7, unless your scanner functions with one of the generic drivers inlcuded in Windows 7.
