Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My washer wnot agitate unless i slam lid
My washer fills up then stops unless i slam the lid then it will start agitating
  • 23 Answers
Is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Posted on Jul 31, 2009
The micro switch is held in with a little plastic clip. Over time the clip weakens and allows the micro switch to move away from the lever on the door. You have two choices. One is to buy a new micro switch. Or do like I did. I measured from the back of the washer to where and cut a dowel rod to fit between the back of the machine to the switch. This will move the switch forward enough to make contact with the lever.
Posted on Aug 03, 2009
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
Maytag washer #A882 Washer fills, but will not agitate. Can hear timer run and after numerous tries of unplugging and slamming the lid, it agitates. My husband doesn't think it's the lid switch. Could it...
Open the lid and in the middle pull the cap off the top off the agitator.
Then remove the little plastic piece, and you should see a 1/2 nut and some little plastic teeth that when the unit is running it locks into those.
Verify by turning with your hand that they are not striped out, If they are then you will need to replace those. If its not agitating it will be more Technical to diagnose.
Also make sure the screw is tight.
Good Luck!
Nov 09, 2009 | Maytag Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
The washer turns on, fills with water, then stops. Agitation won't start unless you slam the lid or sometimes if you "nudge" the setting forward and then pull out and then in.
Sounds like door switch may be failing, or the wiring between door switch and timer has loose connection. You can replace the switch or check ther wiring, or bypass the door switch circuit by jumping the leads at the timer
Aug 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WHDRR418G1WW WASHER WON'T AGITATE OR SPIN, NOT MAKING NOISES. FILLS AND DRAINS FINE.
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Won't agitate or spin
Try slamming the lid a little bit to see if the safety switch is stuck or something. It is probably a child safety thing preventing agitation or spin to start. if the switch is not working properly, then the washer will "think" that the lid is still open. It is to prevent some small child that is unsupervised from falling in it and getting killed. Some machines will still agitate even with the lid up and some wont. There is a little small hole somewhere that has a little switch that the lid hits. That could be the problem. If not I don't know of anything else myself to do since im not an appliance man. Just hope that this helps.
Jul 27, 2008 | GE WJSR4160DWW Top Load Washer
Whirlpool ultimate care II stops during cycle
THe most likely cause for this is either the lid switch or the timer itself sticking.
Sep 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
762 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
