Unit digital display powers up like its working but fan and compressor does not start, I replace the capacitor but it still does the same thing. Your assistance would be very helpful. TY
  • TIM B.
    TIM B. Aug 02, 2009
    Yes, very helpful. We had some electrical work done recently and somehow the feed was not hooked up correctly at the breaker box therefore we only had 110v instead of 220 volts. We took your adviseand activated the 2nd 110 to complete the circuit and it is working excellent now with the 220v service. Thanks so much, jobwell done. TY bye
  • 10,515 Answers
Are you sure that the outside switch is working. As both Fan and Compressor is not working, Kindly make sure that the Ac is switched on and replace the outside switch.Check the fuses, one may be bad. The compressor needs 220 to run. Did you use a meter to check the voltage? Between the 2 incomming lines there should be 220 volts. Try that.
Let me know the update.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 31, 2009
Our hear pump digital display is working but the top fan doesn't seem to be working.we have been away from the UK for and the unit has not been used for a while so cld that be the reason?
If you are talking about the top fan of your outside condensing unit, it could be several things. The fan motor could have failed, the run capacitor could have failed, or the motor is not getting power. Most units have a contactor that turns on the fan and compressor at the same time. If you only have one contactor, the fan motor or capacitor has failed. If you are good with a meter, check to see if you have voltage on the fan leads AFTER the contactor. If you do, I would recommend replacing the fan motor and capacitor
Aug 06, 2016 | Miscellaneous
My condenser fan runs and blows cool air but isnt cooling down the house. Any help.
Check the outdoor unit (condensing unit). Keep in mind, because the condenser fan is running it's not an indication that the compressor is working. On a split system,there's a dual capacitor that serves the fan and the compressor. The capacitor has three terminals.
1. common
2. fan = fan
3. Herm = compressor
This is a common problem; The outdoor fan (condenser fan) runs, but not the compressor (you have to know the sound of a running compressor or you'll mistake it for the sound of the fan) doesn't, because the compressor side of the capacitor is too weak to give it that needed phase angle that it requires to start. If you're referring to the outdoor fan spinning, but no cooling, I can bet the compressor isn't working and needs a new capacitor. Very common problem, I see it all the time. Before you change the capacitor, make sure that you cut the power to the unit, and then use an insulated tool such as a screwdriver and short the terminals together first. A capacitor holds a charge even after being de -energized.Buy the new one with the same exact rating written on it as the old one. Do not mix up the wires when replacing. Write it down or take a picture with your phone
Aug 20, 2013 | Heating & Cooling
I have an 12QZ22TA model. It's blowing warm air. How do you put in freon?
Only an EPA certified Technician can add refrigerant. There are other possibilities why it is blowing cold air.
1. Thermostat is bad (disconnect the power, remove the thermostat, place a jumper wire on the two terminals) Unit starts to cool bad thermostat.
2. Capacitor is bad (look for oil or swelling) looks like a can with terminals.
You can test with a meter.
Instructions Things You'll Need
  • Standard multimeter
  • A/C compressor capacitor
    • 1 Turn the A/C unit off along, and unplug it from, the wall to prevent any power surge to the unit when handling the internal devices. Locate the capacitor inside the unit. Capacitors will come in varying shapes; some will look like either a round or oval cylinder with two or three power terminals on the top. Air conditioners can have two capacitors -- one for the condenser fan and one for the compressor -- and are called dual-run or dual-rated capacitors.
    • 2 Place the probes on the terminals for a run capacitor with two terminals. If the capacitor is a dual-run capacitor with three probes, connect one probe to the herm terminal and the other to the common terminal. You can check the capacitance of the fan for a dual-run capacitor by connecting the probes to the fan and common terminal.
    • 3 Turn on the multimeter and read the display screen. You will see two readings, one for the condenser fan and the other for the compressor. Readings will be in micro farads and seen as the letters "mfd" or "uf."
    • 4 Replace a capacitor if the reading is below manufacturer standards. You can find the required micro farad for the capacitor either marked on the device or in the air conditioner's installation manual. Refrain from testing any capacitor if it is leaking, has corroded terminals or the capacitor unit bulges. Replace it immediately.
Aug 01, 2011 | Amana Quiet Zone 12M12TA Air Conditioner
I have a Trane AC unit, model HIDE036506A which is about 14 years old. The fan and compressor all of a sudden stopped. I can start the fan by hand but the compressor sounds like it wants to start but...
sounds as if the fan motor is getting hot and going off on internal overload (safety). - which causes the compressor to heat up and also go off.
When this happens the usual 'fix' is to replace the motor although you can try replacing the capacitor.
Since you only see one (capacitor) it's possible it's a 'dual capacitor' which means it's the serving the compressor AND the fan motor.
I would replace the fan motor.
Note: I've seen 'shorted' fan motors before - where the blade just barely turns and you would not want to touch the blade because it will give you an electrical shock.
I would be very careful touching the blade of that motor with the power on.-
Jun 01, 2011 | Heating & Cooling
Hello I have a 26 BTU LG split unit AC the capacitor in the compressor unit need to be replaced but I don't know how is the wiring connection the capacitor has three heads remarked as...
Hi, The Capactor that you are talking about is a dual capactor. It works the fan and the hermitic compressor in one. The leg common is power into the capictor, The fan leg goes to the outdoor fan, the herm leg goes to the compressor. Good advice is when you change the capacitor you should also change any other start componants that are also there. I hope this helps.
May 20, 2011 | LG Heating & Cooling
I have a samsung air conditioner - model AQV24NS and after 10- 15 mins it shuts down both red & green lights start flashing. The only wayi can get it to work again is to shut off the main power suply...
Please check outdoor unit. Compressor or fan motor getting high amps due to overheat. Clean condenser coil. If still problem, replace running capacitor. If out door fan less rpm replace fan capacitor. In some unit 2 in 1 capacitor is there. So replace one capacitor will rectify fan and compressor problem. Thanks. Helpful?
Jan 09, 2011 | Samsung Heating & Cooling
3 ton unit compressor dont wnat to start
there is a capacitor connected to the compressor and one connected to the fan ... the capacitors are used to start both (called starting capacitor) ...if its bad then the compressor/fan may buz but not start ..it will kick out once it gets hot .. that thermal cutout will reset when it cools down ... the capacitor may be a dual unit .. that is, two capacitors in one case (one for fan, one for compressor) ... you could have a frozen compressor or bad bearings in the fan but typically its just the capacitor thats bad (make sure the fan turns freely) ... follow wires coming out of the compressor and fan .. some will go to the capacitor ...thats a metal part (usually a rounded rectangular shape about 4 inches) .. the 3 or 4 wires just plug into the capacitor .. replace with the same value (microfarads and voltage) or get an exact replacement using its part number ... mark what wires go where .. make sure power is off befor servicing ..
Jul 25, 2010 | Goodman CLQ36AR49 Air Conditioner
Fan motor will not come on
That thing connected to the capacitor is a booster for the compressor .But if the outside fan doesn't work , the compressor will shutt off on overload because the high pressure in the condenser coil.
First try to replace the capacitor in the condensing unit (it's the only one that works for the compressor and the fan motor) ,but if the fan doesn't start, you need to replace the fan motor.
Sep 14, 2009 | Ruud UBHC Air Conditioner
Replacement of air conditioner's compacitor
I am assuming this is a split system with the condensor outside and the air handler inside. What is the model of your unit? Is the capacitor a dual run capacitor? Is the compressor running? If the compressor is running and your condensor fan is not you need to immediately shut power off to the compressor or you will probably ruin your compressor. If the power went off due to a storm and you don't have power to the condensor fan did you check to see if the circuit breaker to the condensor was tripped. I would check that first. Even if the circuit breaker doesn't look like it tripped go ahead and flip it off and back on again. Even you suspect it is the capacitor you need to determine if it is a dual run (controls the compressor and the fan) or does it just run the fan? If it is a dual run capacitor you will have to get the numbers off the capacitor and try and find a match at the local hvac supplier. If you have a Grainger's in your city they probably will have a match. When working on your unit don't forget you are working with high voltage that can KILL you, If you don't know what you are doing call in a professional. If you decide to tackle it yourself make sure you turn off the power to both the inside unit and the condenser. I always pull the disconnects inside and outside, flip the circuit breakers and turn off the thermostat just to be safe. Then I double check by using my digital multi-meter to ensure the power is totally off. The capacitor stores power so you will have to discharge it by using an INSULATED screw driver and touching the blade across the terminals. Discharge the capacitor AFTER THE POWER IS SHUTOFF. Before you pull the wires off the capacitor terminals I suggest you make a drawing of where the wires are connected. You should have markings with a "C", "F" and "Herm". Even better, I like to take several digital pictures from different angles of the connections. After you remove the capacitor, I would suggest you take it with you to your hvac parts supplier so they can match it. Once you get the right replacement capacitor it is just a matter of connecting the wires back to the original configuration. Then restore the power by flipping the breakers, plugging the disconnects back in and turning the thermostat back on. Most units will not start up right away. They have a 5 minute delay built in to protect the compressor. Good luck and post back and let us know how it goes.
Jun 25, 2009 | Carrier Heating & Cooling
Whirlpool portable AC, compressor works, but no exhaust fan
there are 3 possiblities
  1. something obstructing the lower fan motor (or exhaust motor)
  2. bad fan capacitor
  3. or bad motor
to check any of these you will need to disassemble the unit to get to the blower. there are several screws located at various points on the plastic housing covering the unit. Once removed you should be able to check for motor obstructions visually. for checking the motor and capacitor you will need a volt/ohm meter and ideally a capacitor checker. you could try to spin start the motor while it is powered up this could be a possible sign of a bad capacitor if it will start when you do this or if the motor will spin freely while powered down and will not spin start when powered up. I know that is kind of confusing but its how they work. GO FIGURE.  thanks Peyton
Mar 15, 2009 | Whirlpool ACP102PS Portable Air...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
