There is a good article here that describes how to set up a static IP. Just some notes:
This is what a "Repair" does in your network connection and you will see the changes you applied after the last command.
You did not mention which ports or for which application you want to open your firewall. You can go here and look up specific applications or click on any of the links to get an idea how in general port forwarding is done for your router.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
In order to
configure this, you need to know:
- The IP address of the computer or device to
have the port forwarded to.
- The port numbers to be used and whether these
are TCP or UDP ports
(Note: We
recommend you use a computer that has a wired connection to the
router.)
Setup steps:
