Question about Magic Chef CTB1821AR Top Freezer Refrigerator
Magic chief frig mcbr1010w defrost timer help squence of operatio
Hey i have a magic chief mcbr1010w and the freezer does freeze up and bock the fan now the difrost timer on the bottom back is that it and what its perpose the sequence of operation
The solution to all of the above problems. Disconnect the blue wire from the timer and connect a wire from the white neutral to #1 pin on the timer. As shown the timer operates thru the defrost bimetal
Posted on Mar 15, 2012
  • 3 Answers
Freeser defrosting cycle not working. The freezer back panel must be removed (2 screws) and all ice on the coil melted.
Posted on Aug 24, 2010
4 Suggested Answers
aasc
  • 1606 Answers
SOURCE: Defrost timer might not be working
The timer is located behind the fridge , down by the compressor .
Posted on Aug 23, 2009
SOURCE: my magic chef rb193p fridge wont stop running. I
I had the same problem. When the evaporator heater stops working, frost will build up until there is no air flow to the refrigerator. This will cause the refrigerator to keep running. Remove everything from the freezer and remove the pan at the bottom and see if there is a frost buildup. .... Bruce
Posted on Jul 29, 2011
richroth
  • 9472 Answers
SOURCE: our magic chef refridge is freezing up & the fridge is 60 degrees
You will need to replace the thermostat (cold control) on the unit. Here is the part to order.
Posted on Dec 04, 2012
Refrigerator not cold but freezer freezing
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Jun 16, 2012 | Magic Chef Refrigerators
My refrigerator is not working properly.. the freezer section is work fine.. but the other section is not getting cold...I bought this refigerator six months ago...the model is .. MCBR1010W
Your complaint is not unusual, except that you say the frig is only 6 mo. old. First, I suggest you call the manufacture for warranty service since the unit is still new. There are several items that could cause this problem. It usually will not help by playing with the controls for frig & freeze; the unit should work properly with the controls set at normal midrange for both frig and freez; changing the settings from normal cannot compensate for a mechanical problem. is the refrig in an enclosed space that cannot get good air circulation, or does this frig have the black grid coil in the back and you have the frig up against the rear wall so that no air can remove the heat from this coil ? Any other cause would require mechanical work within the frig components.
Aug 10, 2010 | Magic Chef Refrigerators
Side by side freezer side not working all food was defrosted
When this happens, usually the frig side is also not so cold. If frig shows 50 degrees or higher, you have a defrost control parts failure. Can be defrost heater, defrost thermostat, defrost timer, or the air circulating fan in back of freez compartment. If you are not very capable of removing sections of the inner freezer and do not have good diagnostic skills, best to leave it to a professional. Good luck, Macgivor
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Aug 23, 2009 | Magic Chef CTB1821AR Top Freezer...
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer works fine fridge part not working at all, magic chief
I would look at air flow as the cause. First, look at the inside back wall of your freezer. If you see a buildup of frost, you have a problem in your defrost system (timer, heater or thermostat). Second, listen for proper operation of your evaporator (freezer) fan. I have seen motors turning too slow or blades coming off the motor shaft.
You may also make sure the fresh food door closes properly, and the light goes out inside the fresh food compartment.
Jun 07, 2009 | Magic Chef CTB1821AR Top Freezer...
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
Feb 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side frig not cooling in frig comparment and
Something has failed in the defrost circuit-
Defrost thermostat
Defrost heater
Defrost timer
Reply back if you know how to diagnose electrical circuits, and I'll help you further.
Feb 01, 2009 | GE GSS20IEP Side by Side Refrigerator
Frig shut off
my 7yr old roper refrigerator top freezer stopped cooling and freezing but the light was still on with no fans. I dropped the thermostat cover and jumped the thermostat wires,no help . then i removed the wiring harness from the defrost timer and jumped the #1and #4 .She kicked off. I then replaced the defrost timer and it is running fine now
Jul 16, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 04, 2008 | Magic Chef Refrigerators
Magic Chef CTB1821AR Top Freezer Refrigerator Logo
1,119 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
