Question about Daewoo Microwave Ovens
Touch Control panel of my daewoo KOT-151S microwave needs to be replaced. I have to push control pad several times to get it to operate. Sometimes it will go on after just a few pushes, other times it takes forever leaving me with a sore finger ! Is the part still replacable ? I really cannot afford to buy a new Microwave.
  • Daewoo Master
  • 9,085 Answers
We regularly replace these.
You can send your KOT-151S control panel assembly to us to install a new membrane keypad. The cost would be $64.95.
Or you can order an entire control panel assembly (plastic frame, stainless trim piece, keypad, and control circuit board) for $88.85, which includes return shipping.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 01, 2009
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
Sharp r-509fw Keypad problem?
You need to replace the control panel, the panel is all one piece buttons and all.
Jun 10, 2017 | Sharp R-520KS Microwave Oven
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ewave panel is on lock
As per the owner's manual:
The oven operation can be locked to prevent the microwave from accidentally being turned on. All oven functions can be locked.
To Set: Touch and hold the CANCEL/OFF Pad for three seconds. The Display shows “LOCKED” and the oven beeps.
To Cancel: Touch and hold the CANCEL/OFF Pad for three seconds. “LOCKED” disappears from the Display and the oven beeps.
If this does not work, then try a hard reset: Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you probably have a problem with the controller.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee. It may cost a little more if you need parts, such as a new keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Aug 26, 2009 | Frigidaire Microwave Microwave Oven
Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Jul 13, 2009 | Daewoo Microwave Ovens
Buttons are hard to push, always gives me a
Hi, no need to trash this unit. you can repair this and, its quite easy. the touch pad(key pad) is faulty and, you can purchase the replacement pad, via the link provided below. the instruction will be shipped with the part if you order it from the site. you will need to remove the units cover and, the control panel will be exposed. just replace the bad with the new.
Click here to purchase a new Touch key pay.
Jun 18, 2009 | Sanyo EM-N107 600 Watts Microwave Oven
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
497 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
