Kenmore top loader. agitater won't turn unless you
Kenmore top loader model 110.209 82 992. agitater won't turn unless you apply pressure down on it
    Scholar:
  • 81 Answers
Sounds like the agitator cams are worn out. Pop out the top fabric sofner dome where you would put the downy into. (If your moddel has the green looking snapping ring just below the dome, you would have to snap it upwards and the dome comes off then theres a top cover you jus pop off) . . now you will see the agitator cam. I dont think theres a bolt that holds it down. You have to use a rachet extention that fits into that middle squar shaped hole and unscrew, then take out the agitator cam and replace the 4 little teeth. (make sure you put them in the same way and they slip in there slots ) hopefully this helps...
http://www.partselect.com/KenmoreModels.aspx?ModelNum=11020982992&searchTerm
go to this this link. what you would need is the 3rd picture down. it says "Dog agitator/agitator cams" its the 4 little yellowish looking pieces.
Posted on Jul 31, 2009
NEED DIAGRAM FOR THREADING A KENMORE 158.19802 SEWING MACHINE
The threading on these Kenmores is pretty consistent from model to model (good machine, by the way!). Be sure to ALWAYS raise the presser foot when threading the upper thread--insures the thread seats in the tension disk.
14 Kenmore Top Threading FREE SAMPLE
How to thread Sears Kenmore Sewing Machine 158 12270 158
By the way, the metal projection at the top left of the machine regulates the amount of pressure the presser foot applies to the fabric and feed dogs. Push it down to increase the pressure--important when changing types & weights of fabric. To release the pressure, push down on the ring that surrounds the center projection piece. AND, when finished sewing, it is a "great" idea to always release this pressure button before walking away from the machine. Leaving it pushed down over a long period of time will eventually compress the spring and the pressure will no longer work like it should. Also, be sure to clean and oil your older Kenmore regularly. Use only fresh, good quality sewing machine oil or liquid Tri-Flow Synthetic Lube. Open the top, side, and bobbin area. Gently rotate or rock the handwheel and apply only 1-2 drops of oil every place metal rubs against metal. You can also lube the specific lever and dial mechanisms to keep them operating freely. Do NOT oil belts or plastic gears/parts. Doing this regularly, ie every 40-60 hours of sewing time, will keep your machine running smoothly and quietly and preserve the motor from over stress and possible burn-out.
Dec 31, 2016 | Kenmore Sewing Machines
Can you adjust the needle assembly up higher for thicker garments like thicker coats etc. on Kenmore sewing mach. model 158-13360
On some machines, you can lighten the amount of pressure the presser foot applies to the fabric. (Some machines do not have this capability.) But, you don't want to adjust the height of the presser foot.
If the fabric is pushing in front of the presser foot as you are sewing, you might want to try using a walking foot, a teflon foot, or a roller foot.
Kenmore 158 13360 Sewing Machine If this is like your machine, the pressure adjustment is the upright pin at the top left side of the machine. The inner pin pushes down (in various degrees), the further it is pushed down, the more pressure the presser foot applies. To release the inner pin, press down on the outer ring of the pin. It will snap back up where you can again push the inner pin down in degrees. BTW, it is a good idea to always release this pressure pin when you store the machine. If not, what happens is, over time the spring that applies the pressure becomes compressed and no longer applies pressure like it should.
http://makeitsew.biz/presser-foot-pressure
Sewing Machine Pressure Settings for Machine Quilting
Dec 20, 2016 | Kenmore Sewing Machines
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won¨t start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
The agitater is not working.
have you checked the agitator dogs? here is a video showing how to replace the agitator dogs http://www.youtube.com/watch?v=3iWO4bgRQ40 and here is another one for a kenmore if your unit is not a top loader please message me back with appropriate model number in case yours is a front loader and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
heres your other link http://www.youtube.com/watch?v=yRA08dwufUk
Dec 13, 2010 | Whirlpool Washing Machines
Series 70 washer model 110 26712690 agitator does not move, is this difficult to fix, how much is the cost
it is a .99 cent fix,pop the top off the agitater,remove the 7/16 bolt,pull the top half of agitater off,there are 4 small gears in there called dogs,they need to be replaced,you can get them from your local appliance parts store,put it all back together and your done-mike
Feb 10, 2010 | Kenmore Washing Machines
Kenmore elite top loader how do I get the case off?
Hi, Get me a model # and I can assist you with fixing this issue.
Vic
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I need to remove the agitater from a 90 series kenmore washing ma
remove the top of the agitator by pulling hard at a 45 degree angle toward yourself, grab the plastic piece you see inside with a pliers and pull it straight out, use a 1/2 inch socket with extension remove the 1/2 inch bolt and lift entire assy straight out.
Apr 07, 2009 | Kenmore Washing Machines
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
