Setting tape length to default
I have a dymo labelmanager 150. I can't set the printout length back to the default. It prints out the same length no matter how short the text is. Can anyone help?
    President:
  • 566 Answers
My Dymo 210D will not feed the tape. The little dealy thing goes around, but the tape doesn't feed.
My works Dymo LabelMANAGER 210D broke down because of a weak construction. The tape cartridge door pulls via a spring the print head towards the roller. Its plastic lever couldn't handle the strain. I repaired it with a peace of locking wire, as you can see on the picture. Greetzzzzz Arno
Aug 29, 2013 | Dymo LabelMANAGER 210D - Labelmaker - B/W...
How do I make the font larger on Dymo labelmanager 150
Changing the Font
Six font are available for your labels:
Arial Narrow, Arial Normal, Arial Wide, Times
New Roman, One Stroke and Frankfurter.
When you specify a font size, that size applies
to all characters on current page.
To set the font
1. Press the Font key.
2. Use the arrow keys to move to the desired
font and then press OK.
Also here the link to the manual for further instructions.
http://global.dymo.com/img/compel/Q5S_A-MZSgeJZGJ73tJmbPunig_yx_v1.pdf
Apr 30, 2012 | Dymo Office Equipment & Supplies
How do I reset my Dymo lablel maker I have ! ! ! ! ! ! when in use
!!!!!! is a (rather unhelpful) error code that means basically that it can't print for some unknown reason. If the tape is not jammed in the printhead, and the tape seems to move freely, then generally it means the machine is broken.
To be sure you can call Dymo tech support on 020 7341 55 29 (UK)
If it's under warranty, you can return by going here:
http://global.dymo.com/enGB/ServiceAfterSales/default.html (UK)
If not you'll need another one...
http://www.dymo-label-printers.co.uk/Dymo-Label-Maker.html (UK)
You don't say which model you have, but if it's the one in the picture it should still be under warranty as they're fairly new and come with a 3 year warranty (in the UK at least).
For US or other countries go to www.dymo.com and select your country, and then the returns and contact information can be found there.
Nov 04, 2009 | Esselte Dymo LabelManager 120P Compact...
I took out the tape D1 label cassette for the DYMO LabelManager 210D to replace with a new one - "DYMO D1 Label Cassette" - and a black piece broke/came out with the catridge. I don't know where this...
I know this is too late for the psalter29, but here it is for others with the question. This piece is a cleaning tool. It is stored in the lid to the tape door. There is a small bar in the lid. The slot on the tool slides over the bar in the lid. The soft yellow pad should push down on the tape when the lid is closed. It is a cleaning tool for the print head. The user guide says "gently wipe the pad across the print head". The device should still work without the tool.
Sep 16, 2009 | Dymo LabelMANAGER 210D - Labelmaker - B/W...
Cannot get dymo to print vertically
On mine you use the FORMAT button
Then theUP arrow until you see STYLE
Then press OK
Now press the UP arrow until you see VERTICAL
Now press OK
Sep 15, 2009 | Dymo LabelMANAGER 450 Printer
Dymo LabelManager 300
I would suggest reinstalling the driver.
First disconnect the label writer, then go to :
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Scroll down and you will see your model number and download the drivers. Then run the installation again and it should prompt you to connect the label writer, which should fix the problem
If not also try reinstalling the "Label Software Application" listed on the same page as well.
Jul 15, 2009 | Dymo LabelManager 300 Desktop Labelmaker...
Dymo LabelMANAGER 100+
how do you change the font size to larger print
Sep 17, 2008 | Dymo LabelMANAGER 100+ Printer
Tape Jam
There may be a small piece of label cutting stuck in the gears. remove the label cartredge, you will see a white gear set between the pinch wheel and the print head. Use a micro drive or something strong and give the gears a little help while pushing the print button. You may have to do this several times. Be careful not to use too much force as this may knock a tooth off. Good luck. My Dymo continues to print prefet labels.
Mar 08, 2008 | Dymo LetraTAG Thermal Label Printer
132 people viewed this question
k24674
