I have a 3600 DT and want to install a Linksys Wireless PCI Adapter WMP54G. Is there a voltage I need to be sure to buy and where do I find instructions on how to install this?
  • 32,281 Answers
The PCI adapters are designed to work with the standard PCMCIA slots in laptops. You don't need to worry about voltages. The Linksys wireless adapter will have a driver CD supplied with the wireless card and the installation insructions are straight forward.
Posted on Aug 01, 2009
Just installed a Netgear Wireless-N 150 router and my other desktop - which has a Linksys Wireless-G PCI adapter (model WMP54G) continually toggels between Acquiring Network Address and Not Connected. Are...
if your useing a G network (the router is a G?) then the adapter will attempt to connect via N you have to tell the adapter to connect via G mode only, it cut the speed in half but it should work.
if you have an N router check to make sure the router will accept an N connection. via the network configuration page. depending on the router that may be at http://192.168.1.1 or http://192.168.1.255
Jun 10, 2010 | Linksys Wireless-G WMP54G 802.11g/b
I look for driver
Click below to open the support page for this network adapter:
Linksys by Cisco - WMP54G Support
May 30, 2009 | Dell Computers & Internet
Doesnt work on my msi
www.opendrivers.com/driver/.../linksys-wmp54g-v4-wireless-g-pci-adapter-driver-2.2.7.0-free-download.html
#3 question : network controller questionmark indicates it didnt find the driver it was looking for and shut it down.
Check this site for your driver
Apr 27, 2009 | Computers & Internet
I have a linksys PCI card WMP54G. Worked fine for 1 year now it will not connect. Other wireless computers still get stong signal from router. Checking control panel "wireless connection 7 Not connected,...
This is something to try:
Download drivers for your wireless device from this website. Afterward uninstall your wireless adapter. Then re-install it using the drivers you just downloaded. That should repair the issue(s), if not let me know and we'll take a look at other possibilities.
Mar 15, 2009 | Linksys Wireless-G WMP54G 802.11g/b
Lost the Driver for Linksys PCI wireless adapter, model wmp 54g
Go to your Device Manager and on the right side look and find Network Adapters. Expand the Network Adapter by clicking on it so you can see your Wireless Network Adapter. If it has a yellow exclamation on it then you need to install the correct driver, if it doesn have that exclamation the it may already have the correct driver. It may also be disabled ( red X) so enable it.
Check the wireless connection properties.On the "General" tab and in the middle look for and find "Internet Protocol (TCP/IP)" . Highlight it and click "properties". Make sure here that if you have set-up your router to connection type of DHCP that "Obtain IP address automatically" and "Obtain DNS server address automatically" are the only ones checked.
Jan 25, 2009 | Linksys Wireless-G WMP54G 802.11g/b
Need XP Driver for Linksys wireless adapter, Model:WMP54G I have downloaded driver from linksys site (Ver 4 and 4.1) it is not working. I think i need earlier driver version. Can u help me? Serial no of my...
Uninstall the driver you are using, and install the one from here:
http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/Linksys-Wireless-G-PCI-WMP54G-101.shtml
That'll work in XP and if you want to see if a newer version is available that is compatible with XP, you can Update Driver from the Device Manager and that'll find and install the latest one that still has XP support.
Hope this helps
Chris (ziraffa)
Dec 27, 2008 | Computers & Internet
How did you fix wmp54g Linksys PCI network adapter driver code 10 problem? I googled on this and got tired. Everyone poses this question, but there was no appropriate solution that works around this...
Try this first:
Shutdown PC. Take adapter out. Boot. Install software. Shutdown PC. Put adapter back in. Boot.
If that doesn't work try this:
Shut down the pc before removing or installing adapter.Uninstall device, uninstall software, remove all oem*.inf and oem*.pnf for Linksys products (searched by keyword "Linksys"). Also one of Microsoft drivers was provided for this so I've decided to change its name. After reboot and normal installation procedure everything works ok.
To delete the necessary files go to www.linksys.com/easy and use Netcheck. Easy because this great tool will automatically set-up and install the device for you.
Nov 25, 2008 | Computers & Internet
How do i intall my wireless-g adapter without a CD?
Yes. You can download the needed software/driver for your adapter from the Linksys website. WMP54G has several versions. Verify the exact version number of the adapter that you have and you can download the necessary driver for your adapter. Click the link below and specify the version of your adapter.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859843981&pagename=Linksys%2FCommon%2FVisitorWrapper&displaypage=nodata#versiondetail
Hope this helps!
Nov 23, 2008 | ASUS WL-138G 802.11g/b (wl138g) Wireless...
My Wireless-G WMP54G card keeps Installing Dell Drivers
I hate to say this, but on Dec. 26, 2008, I called Linksys and they said that they don't make a PCI wireless adapter that works with sp3. Mine just rebooted the computer incessantly.
Nov 09, 2008 | Linksys Wireless-G WMP54G 802.11g/b
Computers & Internet Logo
David Payne
David Payne
