Question about Vacuums
Hoover Agility F6215-900 brushes won't spin
I have a Hoover Agility F6215-900 and my brushes won't spin. I have the brushes turned on, and have cleaned the brushes as well, but no luck. Help?
  • 40 Answers
First it has to be on carpet mode. the vibration of the motor could have shook a wire lose or the motor is either jammed of has fried.
Posted on Jul 31, 2009
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Blows air out, not sucking in. Hoover Agility F215-900
It's most likely it's not blowing air out, rather the brush is kicking debris back and out due to loss of suction..
Another possibility with the power head is a cracked or leaky tube between the tank and power head.
For the tank, check all areas for clogs, and clear them.
Dec 19, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover carpet cleaner brushes do not move
did you check to see if the belt came off or its stretched?
Jan 24, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
Where is the belt on a hoover agility?? My brushes stopped spinning and I think that the belt broke but I cannot find it
If you have the manual it should show the location of the screws or clips that hold the cover on for the belt.
Dec 03, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Is my 6215-900 brushes drive driven by a belt? I
No, there isn't a drive belt on the Hoover Steam Vac models.
Oct 24, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Brushes don't spin
Remove the bottom cover and replace the broken drive belt. Check that the brush will rotate freely--likely everything is jammed with hair and dust. The brush assembly should just lift out of the case and the end bearings will pull off. The brush needs to be removed to install a new belt anyway. There should be a diagram that shows how to install the belt (it has a half-turn twist).
Jul 15, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Brushes do not spin on my steam vac
Take the brush block out and see if the brushes turn of, if not replace the brush block. Otherwise it is the turbine(#23) that has to be replaced, sometimes you can take the turbine apart and clean it. The top cover has to come off, turn it over, take out the brush block, take out the screws under that, there are other screws, under where the turbine sits, there are 2 longer screws, if you don't have them out, then you missed them, there 2 screws on the front end of the turbine, unhook the koses and it will come off. This pix. may help:
Mar 02, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover agility
I don't believe there is a belt, check the brush block and make sure that the shaft isn't broken off, if ok, then the turbine is bad and will have to be replaced.
Jan 05, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
F6212-900 / F6215-900 SteamVac Agility
There is no belt, sounds like the turbine is bad and will have to replaced.
Nov 27, 2006 | Hoover F6212-900 / F6215-900 SteamVac...
Vacuums Logo
152 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
