Question about JVC AV-56WP30 56" Rear Projection Television
The red green and blue wont line up on my toshiba
How can i get my red and green bulbs to line up my tv is a toshiba the model number is 43hx70
    Sergeant:
  • 269 Answers
You do have a defective convergence amplifier.
Posted on Aug 01, 2009
How to replace procector lamp in model 46h84 toshiba
Projection TV sets have three tubes - red - blue - green and they don't fail often...they are located inside the tv DLP TV sets use a single bulb and a clot wheel to make the three colors display...DLP bulbs do fail about every two years and will need o be replaced. Replacements can be found at www.TvRepairKits.com and its located behind a small door on the rear of the tv.
May 19, 2013 | Toshiba 46H84 46" Rear Projection...
Image on screen looks concave(middle of screen looks farther away than left or right side.)
Roseannmace,
Your TV is out of convergance. You'll probably noticed that there are red, green, and blue images. You'll need to determine if the problem is in the power supply or the convergance board. Usually, the convergance amps go bad and opens resistors. Do you know how to read a schematic and use a multimeter? You will also need to know how to remove the old parts and solder the new parts into the circuit board.
Ken.
May 27, 2010 | Toshiba 43HX70 43" Rear Projection...
Toshiba 43hx70 Cinema projection TV-where are the IC relays?
DID you ever get this fixed I am wanting to replace mine, I paid big $$ for this tv back 6 or so years ago, the picture cinvergence isnt real bad, but I cant line u the red and blues in the menu as good as they need to be. I was also wondering If i replace the lamp if the tv would be brighter. I have most my setting turned up but...The picture is not as bright and crisp as it used to be any one have a suggestion on this also..
Jan 02, 2010 | Toshiba TN43V71 43" Rear Projection...
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
I can not find a replacement bulb for a toshiba 57hx81. What is the actual part number? Who sells it?
For model no 57hx81 CRT bulb part no.s
Blue is   TOSHIBA     23008753
Green is TOSHIBA     23008752
Red is    TOSHIBA     23008751
If that is not the right model no post a comment here with the correct one and I'll give you the part no.
Sep 27, 2009 | Toshiba 57HX81 57" Rear Projection...
Toshiba 43HX70 convergence problem
One or both of the STK convergence chips have probably failed.
I can give you guidance on this if you are confident to do the repair. I had the same problem with my Tosh 40WH08B and after replacing these chips it works like new.
May 21, 2009 | Toshiba Televison & Video
Convergence problem
sounds like you need to change the convergence chip to me. you can order a kit with instructions from www.tvrepairkits.com for most tv's.
If you plan on doing this you need a good soldering gun and a steady hand.
May 18, 2009 | Toshiba 43HX70 43" Rear Projection...
Blue Halo - convergence issue with 43Hx70
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2008 | Toshiba 43HX70 43" Rear Projection...
Toshiba projection tv
there is no pink in resister codes
red or orange i think it's orange
32 X 8 or 5 32000 32K? most are low resistance
3.9 ohms and below.
Dec 06, 2007 | Toshiba 43HX70 43" Rear Projection...
Hi toshiba 43 rp
You have a confusing mixture of data......Please provide
Make,model,age and chassis off sticker on back of set.....T.
Nov 26, 2007 | Toshiba 53H71 53 in. Rear Projection...
JVC AV-56WP30 56" Rear Projection Television Logo
168 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
