Question about Xerox Phaser 8400 Laser Printer
I am getting an error message of 08.055.44:9347. Every time we go to print the page is blank.
    Scholar:
  • 141 Answers
8,055.44: The Media Drive stalled while engaging headtilt.
Troubleshooting Procedure for Wiper/Media Gearbox
Step Questions and Actions Yes No
Check for obstructions in the Wiper
Assembly path.
Is the Wiper Assembly obstructed by the
Printhead or wiring?
Clear any
obstructions.
Go to Step 2.
2 For an 8,005.48 error:
1. Check for paper in the paper path that is
adding drag to the rollers. Look for paper
or wiring interfering with the take away
roller.
2. Remove the Tray 1 Pick Solenoid to view
the meshing of the Take Away Roller’s
gears to the Media Drive Assembly.
Did this correct the problem?
Complete. Go to Step 5.
3 For an 8,007.41 error:
Check for a missing KL-clip securing the
Head Maintenance Clutch. Replace if
missing.
4 For an 8,009.43 error:
1. Ensure that there is no paper in the paper
path adding drag to the rollers.
2. Ensure the Media Drive Assembly is fully
seated and correctly installed.
3. Remove the Tray 1 Pick Solenoid to view
the meshing of the take away roller’s
4. Ensure the feed rollers are properly
engaged in the drive gears.
Complete. Replace the
Media Drive
Assembly.
5 Run the Wiper Drive test.
Did the test pass?
Go to Step 6. Go to Step 7.
6 Run the Wiper Alignment test (see “Wiper
Alignment Procedure” on page 6-2).
Did the test pass?
Go to Step 8. Go to Step 7.
7 1. Inspect the wiper system for improper
operation, obstructions, or damage
(broken gear or belt). Look for ink in the
Wiper Belt channels.
2. Ensure the wiper system is properly
aligned (see “Wiper Alignment
Complete. Go to Step 8.
8 Run the Head Maintenance Clutch test.
Did the test pass?
Go to Step 9. Replace the
Head
Maintenance
Clutch.
9 Is the head lock mechanism on the right end
of the Exit Module functioning properly?
Go to Step 10. Replace the
Exit Module.
10 Are there obstructions or spilled ink on the
Wiper Blade, the Head Tilt Gear drive path,
or under the Printhead?
Is the Waste Tray overfilled?
Clean the
inside of the
printer and
retest.
Posted on Aug 04, 2009
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Printing blank pages
Press Test Page button on ur printer to check if there is issue with the software or printer.
If print test page is returning a printed page it means there is some problem in software communication with the driver.
Oct 08, 2013 | HP Photosmart C3150 Printer
Spooling error
What make and model printer ?
There are a variety of reasons why a printer may feed a blank page through. This is, in some cases, an error. In other cases though it is a mistake in the page count or a simple matter of the printer trying to maintain itself.
Maintenance If a user has just loaded new paper into the printer or if an error message has recently been cleared the printer may run a blank page through.
Usually this is to make sure that the print path is now clear and that the next sheet it positioned correctly for printing.
Page Count
When a document is edited there is sometimes a blank sheet left at the end of the document. So, for example, if a 10 page document is edited down to nine pages, the computer and printer still sometimes read it as a 10-page document when a user hits the print key.
Page Separator
In some cases where a large number of documents are being printed, users may set a blank page separator.
This puts a blank page between copies of a document to show where one ends and the next begins.
A quick look at the printer's settings or control panel will tell you if this option has been turned on.
Fix a Printer Spool Error
When you send a job to your local or network printer, the print spooler is what keeps track of that job's location in the queue.
If the print spooler is not running, your job will not be able to reach the printer, so it is important to know how to resolve print spooler errors when they occur.
Click on the "Start" button and choose "Control Panel" from the menu.
Double-click the "Printers and Faxes" icon and locate your printer.
Double-click on the printer to get the list of jobs in the queue.
If you see any jobs in an error status, right-click on those jobs and choose "Cancel" from the menu.
Close the "Printers and Faxes" window and double-click on the "Administrative Tools" icon. Choose "Services" from the menu.
Scroll through the list until you see "Print Spooler," then right-click and choose "Start" from the drop-down list.
This restarts your print spooler and allow your jobs to print.
Right-click on "Print Spooler" again and choose "Properties" from the menu.
Go to the "Startup" option and set it to "Automatic."
This ensures that the print spooler starts each time your computer does.
Print spooler
http://social.technet.microsoft.com/Forums/en/itprovistaprinting/thread/cad5221a-d21b-4bf0-8e86-cacae254cb52
Apr 27, 2013 | Packard Bell Computers & Internet
Printer working but page is blank after printing
try this select all in the page that you want to print then press ctrl +p it will show you a window in the bottom of that window press print selection it most work
Jun 22, 2012 | Kodak ESP Office 2150 All-in-one Printer
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon PIXMA MP130 printing blank pages & cartridge jammed message
Hi You can Try
Error Code 5100 Yes see lots of this errors
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Mar 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
HP D7460 printing blank pages, no error message
Just needed to be unplugged (both at wall and at printer) for two minutes. Restarted and it worked fine.
Nov 22, 2008 | HP Photosmart D7460 Printer
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Cartridge Aligment Failure
Then printer successfully printed alligment page you must to put this list on scanner glass to confimation and calibration of printing heads and press "Start or OK", without this part of procedure yours printer will be show error message.
Aug 29, 2008 | HP 190 Copier
Xerox Phaser 8400 Laser Printer Logo
249 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
