Question about Alpine Car Audio & Video
I just installed my new Alpine CDE=HD149BT and it will not startup. All wires seem correct. I pushed the reset button also. Nothing
    Top Expert:
  • Alpine Master
  • 52,784 Answers
There may be an open fuse in the power supply.
Posted on Apr 07, 2018
SOURCE:
simplemitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
localwonder
  • 6784 Answers
SOURCE: alpine v12 amp no power
its your fuse box. i would bypass the fuse box and wire this amp directly to the battery via monster cable. make sure you attach a 30wieght fuse to the monster cable that is running from the battery to your amp. ground the amp against the trunk. scrape the paint of a section and drill a hole in the trunk. use this for the ground for you amp. this will fix the no power issue.
Posted on Feb 12, 2009
  • 2337 Answers
SOURCE: Wiring schematic for Alpine CDE-7856
Download user's guide and go to page # 20 for wiring diagram.
Posted on Jul 12, 2009
SOURCE: setting the clock
hold down the mute button until the screen says clock adjustment if it doesn't saw the use the volume until it does. the press the ENT button in the upper left hand corner then the hour # should flash use the volume button to adjust then press the ENT button the change the minute and when the corect time is in press mute untill the screen is back to normal
Posted on Dec 21, 2009
schast
  • 56 Answers
SOURCE: need to reset the clock on my alpine CDE-9852
Crutchfield has the manual for download here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDE9852.PDF
The clock settings are on page 8 of the PDF.
Posted on Feb 16, 2010
Testimonial: "Thanks so much for the prompt and accurate response!"
When i turn my car on, the head unit doesn't turn on automatically so i have to use the power button. all the preset stations get reset too.
the unit is most likely not installed correctly, make sure the yellow wire has 12v at all times and the red wire has 12v only when the acc or ign is on
Jun 07, 2010 | Alpine CDE-9852 CD Player
I am getting a DC error on my alpine cde-102 head
Hello christo12385,
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
Hope this helps.
Sep 25, 2009 | Alpine Car Audio & Video
Cant turn off
I would imagine that there is a power button on the device itself, however the problem lies in the wiring that was done to install the radio, there is an accessory wire, normally red, that needs to be hooked up to a wire from the car that alternates on and off with the ignition, you can solve this with a volt meter, touching it to wires to see how they react with the ignition switch.
May 07, 2009 | Alpine CDE-9850Ri CD Player
CHANGE CLOCK ON MY ALPINE CDE-9852
push title button til time comes up, then push and hold title button again til time flashes, when it does you can turn the dial til time you want comes up,then hit mode button below dail to switch to minutes , then repeat
Nov 10, 2008 | Alpine CDE-9852 CD Player
CDE-9852
probably the mode you are in, there is a mode for auxillary amplifier that disables the internal pa, in the aux amp mode you won't hear anything.
slonis
Jun 02, 2008 | Alpine CDE-9852 CD Player
CDE-9852 turns off when driving
check your power wire (big yellow wire), your ignition wire (red) your ground wire (black) to the deck it could be a loose connection due to vibration or corrosion
hope this helps
Mar 31, 2008 | Alpine CDE-9852 CD Player
Heating up on back of cde 9852 alpine cd player
try to chek the regulator or replace it and install a heatsink for him
Jan 31, 2008 | Alpine CDE-9852 CD Player
Clock setting for Alpine CDE-7826P
Push the clock button until it flashes. Then push '5' for hours, '6' for mins until you get to desired time.
Aug 04, 2007 | Alpine CDE-7826P
Set time
hit display for clock. hold display button down till screen flashesclock . push 5 for hours. push 6 for minutes.
Feb 10, 2007 | Alpine CDE-7853
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
