Question about Alpine Car Audio & Video
I have alpine cde-984 car system. I have four speakers hooked up to it. How do I adjust the fade.
SOURCE:
SOURCE: SET CLOCL
Hold in title button on the bottom right hand corner
Posted on Apr 16, 2008
simplemitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
SOURCE: Connecting High Speed IPOD Cable to Alpin CDE-9874
Best Buy solved my problem.
Posted on Oct 02, 2008
JustJeeps
  • 74 Answers
SOURCE: Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
Posted on Nov 28, 2008
physicistFL
  • 34 Answers
SOURCE: cannot operate Alpine CDE 9881
Hello!
Hopefully this will help you out.  The manual for the 9881 can be gotten here:  http://vault.alpine-usa.com/products/documents/OM_CDE-9881.PDF
Copy the entire line into your browser, and you will have it.  Don't forget to save it to your system.  It is in PDF format, so if you don't have a reader, pick up one for free here: http://www.adobe.com/
Good luck with the "new" car and radio!
Ken
Posted on Jan 08, 2009
Alpine cde-9842 clock set
  1. In the Clock priority mode, press and holdTITLE for at least 2 seconds while the time is displayed.The time indication will blink.
  2. Turn the Rotary encoder CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the hours while the time indication is blinking.
  3. When the hour has been adjusted, press the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
  4. Turn the Rotary encoder (CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the minutes while the time indication is blinking.
  5. The time is automatically set 5 seconds after the minute adjustment.
  6. The time can also be manually set by pressing the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
Download Alpine CDE 9842 Manual
Feb 05, 2013 | Alpine CDE-9846 CD/MP3 Car Stereo
How do i set the time on my alpine cde 9841?
Setting Time
displayed.
only) or press 4 and 3 (CDE-9841 only) to adjust
least 2 seconds after setting the "hour." Minutes will reset to 00. If
the display shows over "30" minutes when you do this, the time
Or you can ge tthe manual on the link below.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDE9843.PDF
Jun 17, 2011 | Alpine CDE-9841 CD Player
I have an Alpine CDE-100 and when I hooked up my subs and amp I would only get subs with radio and regular speakers for my ipod via usb and the cd player? I had a friend that use to install sound systems...
While I don't know the specifics of this head unit, I would guess that it has settings that can be adjusted for each source. You might check to see if there's a menu that allows you to turn the subs on/off for the various program sources.
Nov 08, 2010 | Car Audio & Video
How do you hook up a subwoofer to Alpine CDE-7858
go into the menu of the radio make sure sub output turn on
Aug 28, 2009 | Alpine CDE-7858 CD Player
How to adjust TIME on Alpine CDE-7856
Once you get the time blinking it is buttons 5 (hour) and 6 (min) that adjust the time.
These are channel buttons on the far right: they are green and are on the bottom edge.
Feb 26, 2009 | Alpine CDE-7826
Can't set the clock
Pasted from the manual:
TITLE/ for at least 2 seconds while the time is
displayed.
2 Turn the Rotary encoder (CDE-9846 only) or
press
up or down arrow (CDE-9842 only) to adjust the
(CDE-9842 only).
4 Turn the Rotary encoder (CDE-9846 only) or
press
Oct 15, 2008 | Alpine CDE-9842 CD Player
How many speakers can u hook up to a cde-9872
yes the alpine can handle that depends on the wattage also might need a amp to go with all that
Sep 29, 2008 | Car Audio & Video
Alpine CDE-9843
Setting Time
displayed.
only) or press
only) or press
Apr 26, 2008 | Alpine CDE-9843 CD Player
Car Audio & Video Logo
29 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
