SOURCE: how do i move my wurlitzer 1015 cd one more time
I take it you wish to transport your jukebox.
If this is the case I would remove all the CD's (keep them in the order that they were on the jukebox for installation again)
The jukebox mechanism will have some form of tie down system that locks down the mechanism tight into cabinet.
Check the power supply, amplifier etc to see if they pull off their mounts. If they do usually on these parts are holes to insert wood screws to lock them down (use the correct length of screw so they do not damage the cabinet) On the title racks or tubes tape them down so they do not come loose in the cabinet.
Try if at possible to transport the jukebox upright in or on the vehical, cover the jukebox with blankets before strapping to the vehical.
Regards
Alan Hood
ami-man
UK
SOURCE: I have a Wurlitzer 1015 OMT CD Jukebox. the
Duff keyboard. It is servicable if you like taking things to bits but not guarenteed to work even then.
SOURCE: My jukebox doesn't play
DOCTOR-FIXCAN MAKE A COPY FROM MY ORIGINAL. MOST LIKELY YOUR PROBLEM IS THE LIGHT THAT COUNTS AS EACH CD PASSES. LOOK BETWEEN CD CAROUSEL, AND CD GRIPPER ARM. A CD MAY HAVE HIT THE METAL LEAVER THAT THE LAMP,
IS ATTACHED TO. YOU HAVE TO GET DOWN 0N IT WITH A MIRROR TO SEE THE LAMP, AND SEE IF THE METAL LEAVER IS NOT BENT. FOR COPY OF WURLITZER MANUAL, A CD RECORD PROBABLY HIT THE LAMP. 636 2273300. NAME IS SEYMOUR LEVITT COMPANY NAME IN-HOME JUKEBOX REPAIR. [email protected] THIS IS A COMMON REPAIR PROBLEM. GOOD LUCK.
SOURCE: IM TRYING TO COVERT MY WURLITZER 1015 OMT CD
To make the jukebox automatically switch between jukebox CDs and the IPOD source, you'll need the background music adaptor. I have these in stock, but need to know which amplifier is in your machine, as different amplifier types require different BGM units. Please email [email protected]
