Question about Kenmore 5.7 cu. ft. Coin Operated Electric Dryer
Disable coin How to disable the coin operation so it can be used without coins
AlmostBob
  • 550 Answers
SOURCE: I just bought a house
  1. purchase a coin insert and blank the slot that coins fit in, then the slide will slid in without coins, just acting like a button, if you examine the slide you wil notice that there are plastic inserts in unused coin slots, any maytag commercial dealer has them.
  2. replace coin slide with 'free operation' converter, which is just a button plate that pushes the striker on the timer switch
  3. take top cover off and just push the striker on the timer, (this is NOT) a recommended option, 220v is enough to spoil you whole day)
Posted on Oct 24, 2008
  • 9 Answers
SOURCE: coin operated machines: slide mechanism is not moving back.
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
Posted on Jan 17, 2009
  • 161 Answers
SOURCE: Coin Operated Dryer Runs with no Coins
so why would you want to fix it
Posted on Aug 28, 2009
SOURCE: I have a Whirlpool coin operated top load washing
I hate this
try insert another coin
if not you will have to run a wire through and a frictioned and magnetised coin might help
if you can you will have to dismantle this part in trying to release it
Posted on Sep 27, 2009
pride applia
  • 232 Answers
SOURCE: change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Posted on Dec 31, 2009
Whirlpool self-cleaning oven: RBD275PDB14 . . . I DO NOT want it to self-clean. Is there any way to DISABLE the self-cleaning feature?
Just don't use it. The finish in the oven is made to work with the self-cleaning operation; it naturally facilitates burn-off at high temperatures. It is normally impractical to remove and replace the finish, besides, it's harmless as far as I know. If you are worried about someone accidentally activating self-clean, you could tape a coin over the self-clean button. (If you have a curious child in mind, the coin may actually draw attention to the button and invite its operation - you know better than I who or what you are dealing with.)
There is no good way to disable the self-cleaning function without replacing the controller with a custom-built and programmed unit. The button is in a matrix with other buttons, so attempts to disconnect it would disable other buttons and generate a controller error that would prevent the range from operating.
Jul 08, 2017 | Whirlpool Ovens
Got washer whirlpool coin operated and All the LED light from panel are on!! What can be happen?
coin mechanism is melfunctioning . Not an easy prob to assertain without being there
Jan 29, 2015 | Whirlpool CAM2752RQ Coin Operated...
Im am 2nd world war artifact collector in searching by means of a metal detector i found 1dollar coin written john adams 2Nd pres.1797-1801 all i want to know if it is a raal US dollar coin. and if its...
I recommend very highly you go to a local coin shop and have the coin checked. There was a 1 Dollar coin minted at one time, very long ago, and it could be worth upwards of $10,000 or more if the coin is real. The coin must be validated and if validated you can then choose to pay for rating. Rating is very important and because of the many grades of rating used for coins it is very important to have validated coins rated by a professional. As an example, a coin rated MS 64 grade is worth $5000 where a coin rated MS 65 grade may be worth $20,000 or more. That is how particular he coin market is with old coins. I am not saying that coin is worth a great deal or money. I am saying it COULD be worth a lot of money and without any other reference there is or pictures there is no way I could even come close to giving you a value, nor could anyone else. At best we would be guessing. In most cases the coin store will verify the coin is real for free but want to charge to have the coin rated. It is well worth the fee for rating, trust an old coin collector. Have fun.
Dec 10, 2010 | Computers & Internet
Change the number of coins to operate
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Disable coin vendor
It is easy to do... Just take the cover's off that will expose where the coin op wire is pluged into the copier. It is a 4 wire clip, I believe. Turn the copier Off and cut the wire on the coin op side and strip the wires. Of the wire's that are there you only need to have two of the wires jumed togather.to make the copier to work. I don't know how many wires are there they may have 2 or 6 or 10, it depends who made it. If you are lucky they may have left the jumper clip in the copier, just connect it again. If not jump two wires and turn copier ON and see it the display is un-locked. If not try another set. It is trial and error. You should be able to fix it. Good Luck
Jan 30, 2009 | Minolta EP4000/5000 CS/PRO Copier
I just bought a house that included in the sale a Maytag Coin-op Washer and Dryer. The coin box on each contains a key. How do I disable the need for putting coins in the washer and dryer so that I can...
Oct 24, 2008 | Maytag Washing Machines
Coin operated washer and dryer
remove the coin slot out remove the slug used to plug the coin slot
Feb 24, 2008 | Washing Machines
Water supply
look on the control board. there's some DIP switches. these are set according to the number of coins needed to run the machine. the coin acceptor reads the number of coins going through it and advances the control board one increment for each "good" coin. objectionable coins are rejected.
Sep 06, 2007 | Maytag MAT12CS Top Load Washer
Washing Machines Logo
74 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
