Http://help.blackberry.com/en/blackberry-curve-8530-8520/current/user-guide-pdf/BlackBerry_Curve_Series-User_Guide-T643442-643442-0319040921-001-5.0-EN.pdf
http://help.blackberry.com/en/blackberry-curve-8530-8520/current/user-guide-pdf/BlackBerry_Curve_Series-User_Guide-T643442-643442-0319040921-001-5.0-EN.pdf
SOURCE: what is the return key on the blackberry curve
it is to the right of the keypad with a downward arrow bending and pointing to the left. it is to the right of the $ key and right below the DEL key. hope this helps
SOURCE: button on my blackberry curve 8330 does not work.
replace ur pannel,if it does not work clean the inner contact of the switch.
SOURCE: BB Curve 8310 keys and trackball not working
is there a way to navigate thru options with no trackball
SOURCE: There is no explanation for
These function keys are synonymous to the Multimedia Keyboard. You can change the volume level or monitor brightness/contrast level by pressing and holding these function keys. For example, hold function key and press volume up key (F4/F5/F6/F7/F8 -- depending upon your Laptop Model) to increase the volume which you could do from the volume tray icon in the taskbar. This is most useful, when you are playing a full-screen game or a Cinema or such like any full-screen operation and do not want to abort your pace of work and get back to the desktop. I have mentioned only one usefulness of this function key and there are lots of such operations if you know them properly.
Now, the Windows Logo key....there are innumerous operations. Such like, the most widely used operation is +D which is used to show the desktop. You are using a full screen operation and you want to go back to desktop in no time, then use this combination. You want to log off (in XP) or lock your computer(Vista/Seven), use +L and your computer will be logged off or locked. If you are using Seven, then when more than two window is open, use +Tab to see what happens!! ( I will not tell you it just now! Enjoy this scenario! ). Due to shortage of time and space I will not be able to explain all the functions just now here......but you can surf the internet for more functions of these keys. I hope, you have enjoyed this article, thanks.
