Question about Intex 15' X 42" Easy Set Pool Complete Pool Set
I have an Intex 15' x 42" Easy Set pool. I bought chlorine tablets for it, and thought I could put them into the skimmer basket. Now I'm not so sure, and I can't get the DVD to play, and I've lost the manual. Can you tell me how I should introduce the tablets into the water? Thank you.
  • blueextc3221
    blueextc3221 May 11, 2010
    open the filter housing and drop them inside the filter.
    President:
  • Intex Master
  • 1,378 Answers
Buy an inexpensive floater for in the water and put them in there. Putting them in the skimmer will just shorten the life of a pump that will already struggle to give you 3 years of service.
Posted on Aug 01, 2009
How do I get rid of frogs in swimming pool
Shock and more chlorine. Frogs don't like chlorine. We have many here in Florida, and I rarely get them in my pool. Dump a couple gallons of liquid chlorine in to shock, then just keep your tablets in a floater or skimmer basket and check chlorine level often.
Jun 02, 2014 | Hunting
I can't get surface skimmer to work
im not sure what or even how you mean "swims away" as properly intalled it has a bracket that holds to pool wall , no the most problem ive seen with these is they sink !! pulling it and bracket right to bottom , this is just an adjustment of water flow thru float skimmer vs side skimmer (normal)
Jun 22, 2012 | Intex Swimming Pool Leaf Catcher Skimmer
How do you bleed the lines to the pump?
I usually run a water hose down the skimmer basket drain for a while until water is returning to the pool through the pump. I hope this helps.
Aug 13, 2011 | Intex 15' X 42" Easy Set Pool Complete...
What chlorine should i use for my pool?
You should use granulated CL in this pool. Maintain CL at 5 ppm - check daily.
Jul 20, 2010 | Intex 15' X 42" Easy Set Pool Complete...
The pump lid has water coming out of it. is that normal? pump was off but water was gushing out when I opened it to put chlorine tablet in filter
Pull the lid back off and check the O-ring...it is not seated properly...reinstall the lid and you will be okay...
heatman101
Jul 13, 2010 | Intex 15' X 42" Easy Set Pool Complete...
Low flow indicator on saltwater pool filter
If your pool has the skimmer system there is a hose coming from the bottom of the skimmer to the wall of the pool which would be your suction to the pump. Disconnect the hose clamp from the suction port that goes through the wall of the pool remove the hose then unscrew the blue adapter on the inside of the pool there you will find a strainer / screen. Whatever gets pass the basket in the skimmer get's plugged up in that screen causing the pump to starve for water causing the LOW FLOW sensor to go off on the Saltwater pump.
Let me know if this helps any.
Jul 03, 2010 | Intex Automatic Salt Water System for ...
I just purchased an intex above ground pool and i need help on where to put the chlorine at
The problem with the floaters is they can drop out small pieces of tablets or granuales and cause bleach spots on the bottom of your pool. Use the skimmer.
Jun 15, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Apr 11, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
Intex system not giving chlorine, no errors but no green light
I found I had the same problem. I would set the hours, it would count them down but the green light would NOT come on indicating it was producing chlorine, yet the sleep light would light up after the count down so I knew the light was working. I checked my salt, made adjustments, had to do shock treatments to keep it clean. Today I  found out that the manual is incorrect in how it says to set it. After you set the hours, instead of pushing both the arrows at the same time until it beeps, push the down button until it beeps, and then the up button until it beeps. For 2 months I have fussed with this system, and finally the green light came on and my test strips indicate it is producing chlorine. Yeah! To bad intex does not seem to mention this on their web site.
Good Luck
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Intex 15' X 42" Easy Set Pool Complete Pool Set Logo
390 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
