Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
19 code I have this exact same problem. The tv has been fixed before by a rca certified tech. He said he replace the "main board". It cost me 450 bucks. I have read on the net that this might be a voltage problem. I am not going to spend too much more on this set. Is there anything I can do to maybe fix this myself. It does the 3 lights at startup deal and then you cant do anything for a minute or so, then hit power and the 3 flashing light sequence. If you hold the power button you get the flashing 1 9 error code. Help please!!
  • 1 more comment
  • arnalh Jul 31, 2009
    RCA d52w19 chassis ITC222
    this is an rca D52W19 chassis ITC222
    I thought I was posting under another thread.
    sorry, but any help will be appreciated.
  • arnalh Aug 13, 2009
    Thanks Yambo, I check all the capacitors you said but only the cp150 was bad. I replaced it with a 2200uf 25v as I could find a 35v that would fit. I hooked everything back up and voila!!! it works again. Thank you for the help. I think that heat sink that capacitor is in has something to do with the failure.
    Champion:
  • 230 Answers
Do this first please.
Replace capacaitors in power supply area
Replace capacitor cp150 (2200mf 16v, ) capacitor CP120 and capacitor cp112
Replace this capacitor too: CP114 (330uf @ 35V ). Upgrade to 35 V all capacitors.
For me is a power supply.
I will be here for any questions.
Thank you
Posted on Aug 07, 2009
Testimonial: "Yambo put me on the right trail and I got my tv back in action for a measley 3 bucks!!! I was really missing my 52 inch. Thanks again yambo."
  • Noe Z  Bernabe
    Noe Z Bernabe Aug 13, 2009
    I am happy too, because I do happy your self !!.
    Thank you.
Rca touch screen constant flickering i cant get it past dogs on screen but even if the dogs are showing or rca logo it is still flickering colored lines how to fix thisis what i need to know
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 13, 2017 | RCA Televison & Video
How do i fix my rca tv that is not powering on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 30, 2015 | RCA E13320 13" TV
I am stationed overseas and bought the RCA L32HD32D TV online. I know it has a bad Backlight inverter board, so I got the numbers off the board and ordered a new one off of Shopjimmy.com. Well the new...
hi,
The only thing you can do is try one more board. May be there was some manufacturing defect in the board you have purchased. May the next one will work for a long time.
ok
Feb 14, 2011 | RCA L32HD32D 32 in. LCD HDTV
My 19"lcd tv has no pic or sound and now flashing red light
if it's new then get it replaced...
else u need to get it fixed from a tech shop....
May 08, 2010 | Princeton Digital LCD1908 Monitor
RCA 26" Flat Screen suddenly no picture
The T-con board has failed but i do not think that it is sold seperately you will have to have a tech check it out if your set is just over the warranty i would contact rca they may just pay for it
Dec 14, 2009 | RCA L32HD31 32 in. LCD HDTV
Replaced Main Board need Diversity Codes
they have to be downloaded onto a flash drive from philips website.. there is a usb port on that model. make sure that the tv is off before plugging the flash drive into the tv. then turn the set on and follow the onscreen prompts..this is the same thing you are going to do that a service tech would charge you 200 bucks to do..make sure you download from philips and not a so called fake..good luck by the way i am a certified philips tach..
Nov 15, 2009 | Televison & Video
Rca r52wh74 - no auto convergance
On this particular model when your convergence is out of alignment, and the auto convergence is suddenly missing from the TV's menu all together, there is a easy fix.
Diode on Main Power supply, Location dl321 and fuse at Location fl231.
This problem has a high failure rate.
Jan 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony kp57hw40 52 in. televison
This can be caused by a problem within the "D" board or a bad CRT. If the D board can be fixed, that would be the least expensive repair. Even so, this will require a service tech. Depending on the cost of an estimate, you could call a service tech and explain that the TV may need a "D board" and try to get it serviced. If the D board replacement does not fix the problem, the CRT would be next. Maybe the service tech would allow you to pay a small fee for the experiment and a fixed service cost if it is the D board.
Nov 29, 2007 | RCA P52926 52" Rear Projection Television
RCA P52151WK- No power
replace cr 4118 an ecg580 is a good sub.
Nov 06, 2007 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
383 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
