Tv works but dont have code for tv its like a child lock a 3-4 digit code the tv is 2007 rca md# 27u414t
  • 253 Answers
Default code is 0000.
If you forget your password you can reset it. Simultaneously press the VOL+ on the remote and the CH+ button on the front of the TV. The display If you forget your password you can reset it. Simultaneously press the VOL+ on the remote and the CH+ button on the front of the TV. The display If you forget your password you can reset it. Simultaneously press the VOL+ on the remote and the CH+ button on the front of the TV. The display to reset, simultaneously press the vol+ button on the REMOTE, while pressing the chan+ button on the front of the TV. Reset Pass Display will appear. Thanks if this helps, please give a good rating
Posted on Jul 31, 2009
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 01, 2013 | Philips Magnavox 27MS343S 27" TV
MY RCA TTE 20V500T TELEVISION IS STUCK IN CHILD SAFETY AND TURNED OFF W/NO REMOTE TO ACCESS THE MENU
Without remote its not possible to disable child lock. If it possible to arrange the remote then you can do the following to override the lock.
1.Press VOL+ on the remote and CHANNEL + on the
front of the TV at the same time. Enter New Pwd.
will appear on the screen. (You must be in the Enter
password screen when attempting this).
2.Press the number buttons to enter a four-digit code.
The code will appear on the screen as you enter it.
3.Press OK to save the code.
4.Press MENU repeatedly to exit the menu or the menu
will automatically disappear within a few seconds if
no buttons are pressed on the remote control
Dec 10, 2012 | RCA 20V500T 20" TV
RCA TV CHILD SAFETY MODE
Not a sure thing but I remember it being hold both vol up and channel up for several seconds to release the unit presuming it is actually locked.
Unlock child lock
Unknown password--ITC008 chassis with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
Apr 10, 2010 | RCA 27F650T 27" TV
I need to remove child lock (without remote)
hi did you get to solve your problem becuase i have the same problem
Apr 23, 2009 | RCA Televison & Video
Child lock on rca r29sfoba
sometimes you can go through your tv menu to solve this problem... or you can get a advanced universal remote from walmart that has the parental button on it
Dec 12, 2008 | RCA F36645 TV
Forgotten password
Your tv is switched on and locked , blue screen and shows keys. A tv with activated child lock can only be unlocked after an 4-digit code is punched in.
Reset of child lock is as followed :
Determain chassisnumber type on type plate on the back of TV.
example: CUC xxxx ( xxxx = 4 digit number).
TV's CUC 6300, 6301 and 6310: bullet.gif Press cursors (blue arrows ) in sequence : Right, Left, Down , Up, followed by OK
TV's with chassis CUC 2003, 2005, 1805, 1825 t/m 1827, 1842, 1894, 1952, 1962, 1983, 1984, 1806, 1828, 1829, 1830, 1836, 1929, 2020, 2021, 2030, 2031, 2033, 2050, 2058, 2059:
bullet.gif Punch in universal code 7038 in. This code ends the child lock
TV's with Chassis CUC 1832, 1930, 1931:
bullet.gif Punch in universal code 7038580. This code ends the child lock Greetz and good luck, and PLS let me know if it works
Arni
Jun 13, 2008 | Televison & Video
Child Lock Code
You will need to go into the parental control and put in 6688 code.This will unlock it.
Feb 06, 2008 | Apex Digital GT2015 20" TV
Unlock my tv
i have problem on my tv i dont know how unlock
Nov 11, 2007 | RCA 32F531T 32" TV
Universal remote
Click Here
For the 4 digit Universal Remote Code List From GE (suppose to work with all GE Universal Remotes as long as they use 4 digits to program.)
Click Here
For the 3 digit Universal Remote Code List from GE (uses 3 digits to program, unless the remote was purchased before August of 2002)
Click Here
For the 3 digit Universal Remote Code List from GE if your remote was purchased before August of 2002.
Oct 28, 2007 | Televison & Video
Televison & Video Logo
341 people viewed this question
Top Televison & Video Experts
Electro Med Services...
