Remember the time when Pole Saw did not exist? People used to use a ladder to reach the distant twigs and branches of trees. But, so pruning used to be a very tedious job which is now an exciting task to accomplish. Now, you do not have to think of pruning such branches with much difficulty because you can get a pole saw. It reliably offers a smooth cutting experience and makes pruning easy and convenient.
If you have a pole saw, you need to understand that possession begets responsibility. So, you should take excellent care of your pole saw. Moreover, its longevity and efficiency would reduce to some extent when you stop caring about the pole saw. Cleaning pole saw blade is a crucial part of maintenance.
So, here goes your guide to clean a pole saw blade.
Do not forget to sharpen the blades with files that fit appropriately in the teeth. Diamond and whetstone files are being widely used for filing. So, this is how you can clean a pole saw blade and maintain it also. It does not take much effort. Invest your time to avoid replacing your favorite pole saw in the future. Keep pruning and contribute to building an eco-friendly environment.
Source: Guide On How To Clean Pole Saw Blade
SOURCE: chain needs to be sharpend
Look at the chain, theresa 3 there and that number coinsides with file size
SOURCE: Have a Remington electric pole saw blade stops
The drive sproket is stripped out. The small plastic gears inside the sproket are worn out causing your problem.You can order part 107713-01 from 1-800-654-8534
SOURCE: need a new 10
Afternoon Lee;
Probably Oregon.
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Select "Remington; YourSawModelNumber; 10; All; All; All".
The Oregon part number can be used at a local merchant (no shipping and handling) or over the Internet.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: I have a RYOBI pole
I assume you have the Ryobi powerhead with the multiple tool shaft (can use it with an edger, blower, trimmer, and pole saw) If so, does the powerhead square drive spin when you squeeze the throttle trigger? Does the chain move freely on the saw end when not connected? Is the attachment fully inserted into the powerhead shaft (small spring-loaded button should pop out of the hole when fully inserted.
SOURCE: on a xRemington gas pole saw, I can't get it to oil the blade
Believe this has small oil pump that is operated by turning of the chain sprocket, clean all holes and if this does not fix check the pump sprocket.
