Question about Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe...
I replaced the freezer motor this morning because it was veryb loud and the new fan is spinning but now the freezer is 31 F and the frig is 62 f...what did I do wrong?
    Problem Solver:
  • 14 Answers
Which motor did you replace? Is it going in te the right direction? Check the RPM's of the new motor vs. the old. If you have a clamp meter, you can also do an amp draw to see what the amperage is and then check on the nameplate to see the correct amp draw off the motor.
Posted on Jul 31, 2009
My LRFC25750ST is making a loud humming noise every time I close the frig or freezer door...what can be causing that?
your fan on frig is just wearing down the longer you have frig they get that winding noise from fan replace fan.
Feb 24, 2011 | Refrigerators
The fan in my freezer was making a loud noice for several weeks as if it was having a hard time starting & now it is not working at all. The temp. in the freezer still remains the same. What will that...
Without a freezer fan the temp. in the frig will rise and the milk will spoil. After more days the temp. in the freezer will rise as well. Without a freezer fan the air is not moving, so naturally the the evaporator will ice up. Worst case the motor will smell like burnt. the frig will suffer 1st then the freezer. someone can get sick be careful. hope this was helpful replace the motor
Mar 30, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer is 0 degrees, frig is room temperature. What is wrong?
There's a fan assembly that moves air from the freezer to the fridge. Typically this is on the back wall, center, just behind or above the thermostat.
Your fan motor has failed, so it's no longer spinning the fan blades. Take this motor and fan assembly out and take it to an appliance parts store, and they'll be able to find a compatible replacement part.
It should be in the $15 - $30 range.
Oct 20, 2009 | Dometic Refrigerators
Loud compressor noise from lg frig...
The sound you hear is the Freezer Fan, this problem is hard to diagnose, because the fan spins but not fast enough to circulate chilled air thru the freezer and refrigerator. The minimum labor and material cost for the repair/replacement is around $300.00. But if you chose to make the repair yourself the motor alone costs around $80.00@appliancefactoryparts.com. But the repair is very labor because the electrical connection for this fan is at the rear of the unit
Jul 30, 2009 | LG LRSC26940ST 36" Side-by-Side...
Put new mother board in refrigerator and it sounded like everything was working good but in the morning there was a loud noise in the freezer
sounds like the circulating fan is wearing out, this fan has a dc motor that wears down over time, when it starts the noise it generates is very annoying. What happens is the stator or spinning part of the motor wears down. This fan motor is around $80.00 if you purchase it and replace the motor yoursefl. But the minimum cost to repair/replace this fan assembly labor and parts is around $300.00
Jul 23, 2009 | Refrigerators
My side by side makes a loud humming noise from the freezer when the frig is running can you help solve this promblem or do i need to buy a different brand to solve this promblem for the second time
most likely it is the evaporator fan motor.you can replace it but know telling how long the new part will last.not very expensive part but very easy to replace.once you take the back panel off in freezer you will look above the coils and you will see your fan motor.
Mar 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
New refridgerator delivered this morning to replace the same model that was a lemon. The fridge is making a sound on the fridge side. When I open the door to the freezer side the sound stops. When I...
sounds as if there is an issue with the evaporater fan motor, perhaps the fan blade has come dislodged and is makinf noises, normal for the fan to stop when the frig door opened as welll,
Dec 17, 2008 | Refrigerators
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Jul 31, 2008 | LG LRFC25750 Refrigerator French Door
Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe... Logo
56 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
