Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Amber Flashing Power button on bootup
I removed the Panasonic CR2032 battery from the motherboard based on a suggestion from another individual. Shorted it and then reinstalled it. System loses date and time, but then allows computer to boot up. I normally leave the computer on all the time now. I cannot believe based on all the similar problems with the Dell Dimension 5150 that Dell refuses to help individuals, provide a fix for the problem, or recall the computer.
  • 114 Answers
I would change the battery first of all. this is the reason for losing date and time
Posted on Jul 31, 2009
Dell Power Edge 2900 - amber and Red A light on tape Drive
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. May also be a defective card inserted into your motherboard. Try isolating the problem by removing all components until you just have motherboard and power supply and see if it turns on.
Feb 13, 2014 | Dell Computers & Internet
Thinkpad not turning on, Flashing Amber light when battery inserted
The problem is most likely in the DC jack in the laptop, "common issue" the laptop must be dismantled down to the motherboard level, chances are the main board must be removed from the bottom chassis and flipped over to expose the solder joints underneath the DC jack and a resolder touch up done.
May 01, 2012 | IBM Lenovo ThinkPad SL510 28479YU Notebook...
Keyboard failure message during bootup
There's a good chance that all you need to do is replace the battery which most likely is a cr2032
Jan 17, 2012 | Dell Dimension 8300 PC Desktop
Orange light remain on switch after powered on computer
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
If the power button is solid amber, then there is a motherboard failure or a failure in something connected to the motherboard.
Remove any expansion cards and all external connections, if no change replace the motherboard
If the LED is flashing Amber, most likely the power supply
Jul 12, 2011 | Dell OptiPlex 360 Desktop Computer
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
How to change battery on asrock k7s8x motherboard
A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 03, 2011 | Asrock K7S8X-R3 Motherboard
Dell 6000 power problem?
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Mar 24, 2010 | Dell Inspiron 6000 Notebook
Dell Dimension E510 Problem
here are just a few things I would suspect.
One of those windows in the BIOS settings will display all the voltages at spec and the actual voltage. There should not be more than a 10% difference above or below. As you seem unafriad of your computer could you remove the left side and see what the make and model of the power supply is. It should give spec and voltages.
Second is your Cmos battery weak, was it individually packaged and is there a date on it, Try getting one from a different source to make sure you are getting a different lot or try a different brand. Look at the contacts on pc for the battery look for signs of oxidation. Look at the soldering to see if it looks damaged or bad, they can crack or break. Some one with a tester could check them to see if they are good. Of course, make sure you are connecting the battery with the correct polarity. Also, check for a leaky capacitor on the motherboard.
When you are taking out the cmos are you just immediately putting the new one in and then restarting? If so do this instead, unplug from power, remove cmos battery, leave it just like that for at least 30 mins. This allows a good power cycling. Then replace with good new battery (you can have the battery tested for strength) if battery has date codes you can check for freshness, you want to try to get a fresh one, after install of battery, plug in and try it. Sometimes a minimum 30 min power cycling resets things. Also, What else is installed and how much "stuff" is connected to the USB ports but is not self powered? Now the amber light ... Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the battery. Plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it). Those are a few things to look at for now.
Nov 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell SX260...Wont Boot...Power Button Flashing Amber....grrrr!
Try these (un order of degree of difficulty) 1. Try replacing the battery on the system board. it is  typically a CR2032 button-style battery. This helps if the computer has been off for a long time.  2. Make sure all dust has been blown or vacuumed out of the computer. 3. Check to see if the USB pins are bent inside the connector on the back and the front of the computer. Straighten if possible. 4. Remove add-in cards, fans, shrouds, and heatsinks, then check the system board for leaky or mushroomed capacitors. If you would like, this may also be a good time to see if the processor is seated correctly or possibly short-circuited (burned black on the bottom, burnt or missing pins, etc). If it is any of these, you may need a new system board (motherboard) 5. It may be that you need a new power supply. Do your best to make sure that it will fit your computer case and have all the power connectors you need; they are not created equal.
May 05, 2008 | Computers & Internet
4600C no power, flashing amber light
FLASHING AMBER LIGHT FIX. This maybe in fact a motherboard issue, but actually its a bit more. You can and should replace the power supply with a more powerfull one as it will help overall, but the issue is Really the front USB ports and 2 issues concerning them, 1 some devices pluged into them have boot sequences of their own, (remember your boot seq goesfrom,USB,CD,ARRAY)etc.
So if the device isnt design with its own OS, the mis-boot will get stuck Hence the Flashing light. and 2. the front USB ports dont supply alot of power upon bootup. and the devices pluged into them will again cause a mis-boot. Simply unplug everything from the FRONT usb ports. You may have to shut the computer off and unplug the machine for about *15* minutes.
Enough to get the motherboard to downpower completely.
with the front usb ports clear, and the power cord unpluged, hold down the power button and plug in the machine. should boot no problem. So to sum things up. The motherboard is fine, it just not happy with so many usb ports (power wise). A larger power supply is a good idea but wont entirly fix the issue, Unplug front usb devices as they may have some form of bootup.
Jan 19, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
198 people viewed this question
Alun Cox
