After put mute and 1,8,3 tunning lines green red and blue how memorizer i have two remotes one is 00220a and another is 8p59-00008a
    Brigadier General:
  • 4,090 Answers
Sorry your explanation is not clear enough for me to assist you
Posted on Aug 01, 2009
Need color code for 16 pin connector, power plug
Pin Number Wire Color Function 1 White Left Front Positive 2 Green Left Rear Positive 3 Violet Right Rear Positive 4 Grey Right Front Positive 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front Negative 10 Green/Black Left Rear Negative 11 Violet/Black Right Rear Negative 12 Grey/Black Right Front Negative 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
Sep 18, 2015 | JVC KW-AVX706 Car DVD Player
Pioneer KEH-8031ZT connection diagram of power and speakers
There are two kinds of pioneer color codes:
pre 1999
P o w e r Memory (+12v Constant) Orange Ignition (+12v Switched) Red Ground (-) Black Illumination Yellow Phone Mute Yellow/Black Power Antenna Blue S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) Green Left Front (-) Green/Black Right Rear (+) Gray/Red Right Rear (-) Black/Gray Left Rear (+) Green/Red Left Rear (-) Black/Green
and 2000 or newer
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Jul 01, 2011 | Car Audio & Video
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
Toshiba 57H82 convergence problems. TouchFocus
See my solution <http://www.fixya.com/support/t2795690-convergence_off_blue_line_only_vertical>.
You need to get to the service menu--it's been 4 years so go to AVSforum.com to turn off the different guns and get the better pattern.
At your risk: To get into Service mode:
1. Turn your TV on. 2. For X81 or earlier series: Press MUTE on your remote and release. 2. For H80/H81/HX81 series: Press MUTE on your remote and release two times ("Mute" on-screen) 3. Press down MUTE on your remote again and hold. While holding, press the MENU button on your TV set's front panel. 4. Release both buttons. 5. An "S" should appear on your screen. Press MENU again on your TV. 6. Now you're in service mode. Channel Up/Dn - Scrolls through Parameters and Volume Up/Dn - Changes Parameter Value
To get into convergence mode:
Get into Service mode, then Hit '7' to bring up the convergence grid. Buttons 100, 0, and ENT control which gun you want to turn off (if you want to align the red to the green without seeing the blue gun and other variations). 2=up, 8=down, 4=left, 6=right, 3=change gun to converge, 5=converge that point. To exit convergence mode you press 7 once and your screen should look like it's imploding then return to normal and then you press 7 to get back into regular service mode.
I have more info found on the board. -Ken
Jul 31, 2009 | Toshiba 57H82 57" Rear Projection...
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
Toshiba TP50H15
You can adjust the lines and make them straight. You can also in the same process, make them line up.
1. With the TV on, press the mute button the remote control so that you have picture but no sound.
2. With remote in one hand (holding it as far from the TV as you can but still be able to reach the TV with your other hand), press and hold the mute button again, with the other hand, using the control panel underneath the screen, press the menu button on the TV set.
You will notice an "S" on the screen on the right hand side about 2/3 from the left, halfway up the screen (If you did this right).
This means you are in service mode.
With the remote, curse right only once and you will have some information displayed in the upper left. The top line is Item, the one underneath is Data.
Press "7." This will display the built in cross hatch pattern. You can move the line around with the directional circle located at the center of the remote. Using the "3" button, you can decide which color to move. To move the curser to a new location, The number pad doubles as a direction key pad. (2-up), (4-left), (6-right), (8-down). To simplify the process, you can eliminate the red or blue or green lines and only focus on one color at a time. "0" will shut on/off the green line. "100 button" will shut on/off the red line. "CH RTN or Enter will shut on/off the blue line.
"7" will exit the process as well as get you there.
Power off when you are done and turn back on.
Repeat as needed.
Jul 05, 2008 | Toshiba 50HX81 50" Rear Projection...
My red convergence is out, and it will not change
when thes tvs get around 4 to 5 years old the convergence go's out on them there are 2 stb's or someting like that it may be stc's i can't remember what they call them it's been so long sence mine did 1 has probbly went bad i chould control the red but not the blue and sometimes when this happens it will also blow green fuses as well in my books they should put cooling fans in these tvs to help cool them there is to much heat inside the tv thats why they only last a few years before having that problem i have 3 of them and all three of them did the same thing you can check the remote eye on the front of your tv sometimes when there is a problem the green remote eye will flash acode but you will have to have the service manual to find out what what the code means
Jun 25, 2008 | Akai PT5598HD 55" Rear Projection...
Samsung HDTV
If you changed the ICs you need to adjust convergence, read carefully the instruction and alingn the lines using remote control commands. Is a long process. My tv loss convergence three times , i will never buy another samsung product. I told every body that i know that never buy another samsung product.
Oct 26, 2007 | Samsung HC-P4752W 47" Rear Projection...
Convergence
Replaced convergance power packs (2) stk392-110 check all 2watt resistor the packs, to enter the convergance alinment mode on the set. Using the remote control press and release the sleep timer button when sleep timer displays timer equals zero immediately press the display and V. status buttons at the same time.  If done quickly enough the service menu will appear once entered the careful not to does disturb or change any other settings press the number seven to enter the convergence alignment mode a full crosshair pattern will appear in this alignment mode you can adjust the blue and the red to line them on the green using the select and the number pad you can move to the next crosshair to align the boot to the green and then the red to the green when done pressing the muting button on the remote control will save your changes will take a little while to figure this out as you work with.  If you make an unwanted error pressing exit without hitting the muting button will restore your convergence to its previous  setting.  If you're green is off after entering the service mode press the number six on your remote control in this setting will be able to adjust the green only once that is done us the muting button.  Then enter button seven if need be to adjust the blue and the red.  Remember no changes have been stored until the muting button is pushed open this helps.
Oct 14, 2007 | JVC AV-48WP30 48" Rear Projection...
SERVICE MODE
I have a tv bluesky model PR14 .can anyone help me with service mode-
Jun 10, 2006 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
