Question about Panasonic Lumix DMC-TZ1 Digital Camera
I dropped my Lumix and the little lever in a battery compartment got broke.
I dropped my Lumix and the little springed lever in a battery compartment got broke, so the cover no longer holds the batteries. How could I possible repair that
  • 619 Answers
Maybe you can do by yourself but its wise let technician to do it more knoledgeable to do it.
Posted on Dec 28, 2007
The latch of the glove compartment broke. Can't open the compartment
If you look under glove box you will see two to four screws that hold the glove box on. Take out the screws and the glove box will drop down and you can get inside and release latch..then you can get a replacement latch and replace.
Sep 19, 2015 | 1995 Buick Regal
Shifter release latch broke
They call it the little pink thing. Inside the shifter box there is a little pink spring loaded lever. The arm breaks and locks out the shifter. Easy enough to get to. I drilled small hole in the lever close to where it broke off and put a small piece of a paperclip in it and reattached the spring. My brother who had had the problem earlier paid about 275.00 dlrs to get his fixed. It cost me about two hours and half a paperclip. works better and guaranteed to last forever. This has been a very consistent problem with Chrysler and they will not recall it. We can make it better. We have the technology.
Apr 02, 2014 | 2006 Dodge Charger
I broke remote how do i replace it
You can try taking apart the remote and soldering in a new spring from places like Radio Shack
Jan 30, 2013 | Curtis Televison & Video
Battery button broke
Well, you might try a jeweler to do the tiny work inside your camera. The other place, besides the Factory, would be a Camera repair place. Look in your local phonebook.
Jan 23, 2012 | Olympus FE-280 Digital Camera
How do I remove the memory card from my Lumix 8x Vancouver 2010 camera?
The card is in the battery compartment. On the bottom of the camera, slide the release lever in the direction of the arrow and open the battery/card door. To remove the card, push the card until it clicks, then pull the card out upright. Hope this helps.
Mar 13, 2011 | Panasonic Lumix DMC-FS3 Digital Camera
How to reset
Hello, Just remove the batteries. Also the batteries should be alkaline batteries. Not lithium, Ni-Cd, Mercury etc. Now, I'm giving you a little trick that I learn over many years work with electronics. Take piece of wire and make sure the batteries are remove. Take piece of tape and tape one end of the wire to the positive side (+), all it will be is little shinny plate. Now take the other end of the wire and tape it to the shinny spring this the negative side(-). Rember, there are two "AA" or "AAA" batteries.
The wire goes from + of 1st battery end in the battery compartment to negative side (-) of the second battery spring (-). Rember!! NO BATTERIES, while you are doing this operation. Let the wire stay on the battery terminal in the battery compartment for 5 minutes or so. What is does if the electrolytic capacitor is holding and want drop the current which switch is turn off, it will now.
Reinstall the correct batteries then turn on your ITT Mariner 160 monocular. GB...stewbison
Feb 03, 2011 | ITT Night Mariner 160 Monocular
Broken Part
i am stea in dubai my coolpix little lever holding the battery in broke off ware is servise centre
Jun 24, 2009 | Nikon COOLPIX S9 Digital Camera
Says low batteries and shuts off. Batteries are brand new.
1. clean and adjust the springs in the battery compartment
2. use the right batteries, alkaline or NiMH, etc.
this tips may help
Why my camera keeps saying ‘change battery’ even with new batteries?
May 18, 2009 | Panasonic Cameras
I have a broken battery holder that I am going to try and replace
Hey, if you want to DIY, the $1.00 BATTERY HOLDER is not the right part you wanted. The little thing doesn't come separate. What you need is called BATTERY FRAME. The tiny battery lock and spring are included in the Battery Frame.
To replace the BATTERY FRAME maybe not easy. My suggestion is take the battery lock from the new Battery Frame to replace the broken one.
Mar 18, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
HP Photosmart R927 Battery Compartment door latch
Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
213 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
