Question about Dishwashers
AEG Favorit Sensorlogic turbodry
The machine won't start it just beeps.
I need to know manufactures year of AEG favorit 80860
Posted on Oct 29, 2009
AEG favorit sensorlogic has no power.
Electronic is protected against short circuit throught out VDR - voltage dependent resistor which is located on the electronics. Unfortunately, when this happens usually get hurt some other component part or burn printed circuit boards.
Any intervention on electronics requires qualified person otherwise there is the risk of fire or electric shock.
Dado
Jun 20, 2015 | AEG Dishwashers
I have a AEG favorit sensorlogic , it may be commercial , why would it have a live and a neutrel cable running down the water supply pipe into the back of the machine ?
if its in side the water pipe then theres a fault.there is not really a problem with it so long if the pipe is not leaking
Oct 14, 2012 | Dishwashers
I have an AEG Favorit Sensorlogic Turbodry and it wony start. You switch it on and the onlycycle button that lets you press it is AUTO but it does nothing and then after a couple of minutes it just starts...
could be the drain pump thats blocked /jammed or faulty. the first 2mins the pump is energised if it does not run the electronics sense this and cancel the prog. Also similar if no water supply or if water valve faulty after 5mins. Dont think it will be aqua flood control as pump would run and alarm sound instantly. more mysterious problems can be heater down to earth. and lastly the electronics itself.check the others first though.
Aug 24, 2010 | Dishwashers
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
Nov 09, 2009 | AEG 24 in. Favorit 60870M Free-standing...
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Hello, we have the AEG 60820 Sensorlogic dishwasher but no instruction manual. Please could you tell us when we should use the ''Automatic'' button and the ''Energy saving'' button? And what the advantages...
With the auto setting, the machine detrmines the time based on the load. With energy saving, you force the machine to use the least amount of water and heat, usually best for cups and glasses.
Apr 26, 2009 | AEG 24 in. Favorit 60820W Free-standing...
Dishwashers Logo
2,188 people viewed this question
Top Dishwashers Experts
