Question about DeLonghi Pinguino PAC-77E Air Conditioner
My Delonghi K900 overheats after only an hour of use. It is so hot, I'm afraid it will start a fire. Also, it only cools the indoor air to match the temperature outside. I thought I was purchasing an air conditioner that would actually cool the air.
    Problem Solver:
  • 9 Answers
Hello, have you tried shortening the length of the exaust hose, portable air conditioners rapidly loose performance when the hose is long. The exaust hose needs to be as short as possible with the fewest possible bends. The overheating is usually caused by the unit struggling to push the heat away from it, this would also explain the less than satisfactory performance. Another thing worth checking is that the filter and the fins on both radiators are clean as dirt will decrease its ability to move heat. Hope this helps.
Posted on Aug 01, 2009
Our AC keeps cutting out. It runs for a few minutes then stops. have to switch off and restart. Any idea why? Have emptied water and cleaned filter recently
Look for:
  1. the ac needs air flow thru the indoor and outdoor radiators
  2. the outdoor radiator coil should get warm/hot and produce warm air.
  3. indoor radiator coil needs should get cold and produce cold air.
The ac needs the fan motor(s) working and compressor running and pumping. Compressor skinny copper line hot and thick line cold.
Jul 21, 2015 | DeLonghi Heating & Cooling
I have a delonghi pinguino k900 which I purchased in 2003. for the past 2 years it only acts as a fan. what do I need to do?
Check last pages of your user manual there is the number to call repair service, the heater element must be replaced
Jul 25, 2008 | DeLonghi Heating & Cooling
Delonghi problems
may be a bad scroll. Have the compressor checked by a pro.
Aug 19, 2014 | DeLonghi PACA120E Portable Air Conditioner
Error code 14
This is the latest I have. recommend calling Rheem customer service. They are very good
14 Overheat Wrap Fault
Ensure high fire and low fire manifold pressure are correct.
Check gas type of unit and ensure it matches gas type being used.
Check heat exchanger for cracks and/or separations.
Ohm out safety circuit.
Check for improper conversion of product.
Check for restrictions in air flow around unit and vent terminal.
Check for a foreign materials in combustion chamber and/or exhaust piping.
Jul 14, 2014 | Rheem RTG-84DVP Indoor Propane Tankless...
Cooling fan will not turn off
Sounds like the fan relay is stuck. You should be able to pull the relay or the fuse to make it stop until you can get it fixed.
Jun 30, 2013 | Buick Cars & Trucks
Delonghi Pinguino K900, continued to blow hot air, what should be the solution. I want to enjoy the airconditioner aspect of the unit.
There a several things that can cause the problem you have described.
1. The Dehumidifier Mode is operating at the same time as the AC or is operation on it's on.
In dehumidifier Mode heat is produced.
2. Air filter needs to be removed and cleaned.
3. A blockage or crimp in the exhaust hose.
4. The exhaust has a leak or has come loose from the unit.
5. The unit is sitting in direct sunlight or is adjacent to a heat producing appliance.
6. Compressor needs to be recharged with R134a refrigerant gas.
The 6 things listed above are where you need to start troubleshooting. 5 of which are easy to check and correct.
Hope this helps you and thanks for choosing FixYa.
Jul 21, 2011 | DeLonghi Pinguino PACL90 Portable Air...
How do i set up the DeLonghi Esclusivo indoor grill
Hi there.
I have seen Delonghi indoor grill Manual of Models BG22, BG24, BG35, BG45, BQ100 and CGH800 at http://www.delonghiusa.com which includes illustration on the grill set up.
You can download the Manual that matches the Model of your Indoor Grill.
Regards.
Jul 16, 2011 | DeLonghi Perfecto Healthy Grill Indoor...
Will a crack in the shell make the heater leak??
If the metal has cracked, it is only a matter of thime before it starts to leak. I wouldn't use it unless you are home. If it does leak, it can cause the heater to overheat and be a potential fire hazard
Jan 28, 2010 | DeLonghi 6707E Oil Filled Radiator Heater
Delonghi pinguino k900
Try this link. I do not see a "K900" but maybe it is a start.
http://www.delonghi.com/Int/USA/customer.html
Jun 15, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi piguino k900
does anyone no where to find a user manual for this air conditioner?
Jun 08, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi Pinguino PAC-77E Air Conditioner Logo
410 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
