Question about Home
Water flowing through power shower on or off - Home
  • 744 Answers
Sounds like you either have a very leaky washer or the shower cartridge is stuck. You may have to turn off the water to the house since many shower valves do not have separate isolation valves.
Posted on Aug 01, 2009
I have a powerstar tankless water heater that runs my kitchen and bath room. The sinks get plenty hot but when you turn on the shower it stays ice cold and the power light just keeps going on and off
Shower heads have flow limiters installed in them. This means the water heater cannot sense the water flowing and therefore it wont come on. Take the shower head off and look in the end for a piece of plastic that is in the swivel. Remove it. Then put the shower head back on.
Dec 05, 2017 | Water Water Heaters
Selectronic redring shower powering up , no water coming out and then turns off after approx 10 seconds
There are some troubleshooting actions mentioned on page 6 and 7 of the manual at this site
http://www.aroundtownflats.com/manuals/Shower%20Manuals/Redring/New%20Selectronic%20Instructions.pdf
The shower is designed to turn off within 30 secs if there is no water flowing through. The issue is why does water flow stop.
It can happen if shower is in overheat shutdown. Need to find if temperature setting is too high. There is a purge sequence to overcome this. See manual.
Apr 21, 2014 | Home
Hi my bosch tankles water heater lites up and the goes out any ideas what i should check. best wishes
Hello, Your Tankless water heater will briefly turn on when the propane is turned on and you switch it on but it only stays on when the shower handle is turned on to allow the flow of water. The water faucet must be on obviously. The unit will only stay on while the water is flowing out of the shower head.
If the unit doesn't turn on there is 3 things that will prevent it from operating correctly; 1. Batteries must have a charge /power. 2. The propane fuel must be on. 3. Water must be flowing from the shower head regardless of the spray pattern.
Good Luck!
Dec 18, 2010 | Bosch & Tankless Water Heater
Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Our Aqualisa power shower lacks water pressure power
more than likely you have some debris near the shower head
take an adjustible wrench( crescent or channel lock
wrap a rag around the eustaceon( chrome tube coming out of shower wall srap around tube to protect the chrome hold it firmly with vicegrips or channel locks, take adjustible wrench or chanel locks and remove the chrome nut holding the shower head on to the eustaceon(turn counter cockwise be careful not to drop the tools that wil damage the tile or fiberglass
after removing showerhead
turn on shower to force and debris out and place shwoer head into stream of water to clean out any deposits the head may have some type of screen to strain the water
this should work if the flow has not incresed then there is a need to adjust the flow valve at the control
to reinstall the shower head reverse procedure
if you have any teflon tape wrap it around the threaded portion of the eustaceon
good luck
hoe this works
Dec 27, 2008 | Home
Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Aug 30, 2008 | Home
Power showers
Try removing shower head-look for debris. I seems you might have lost water flow.
Aug 27, 2008 | Home
Home Logo
98 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
