Question about Dryers
Lint screen collects very little lint. - Dryers
    President:
  • 704 Answers
That is actually a good sign, since link is basically your clothes wearing away, one little piece of fabric at a time (lint).
If you're using a washing machine that is newer (front loader or top loader) that doesn't have a traditional agitator, that is helping to keep the lint, as you're not beating up your clothes as much.
Another big contributor to getting a bunch of lint is fabric softeners, which help break down the fabric fibers in your clothes to help make them feel soft, but it helping to wear them out too.
Another thing to check is to make sure the exhaust vent is clear all the way from the dryer to the outside, as a partial blockage could be preventing a full flow of the dryer air to the outside and thus another reason you might not be seeing much lint on the filter screen.
Hope this helps and best regards!
Posted on Jul 31, 2009
  • 334 Answers
Sounds to me like the air flow in your drier is minimal. I would check first to make sure the hose that is taking the air outside is not filled up. That is not at all uncommon. Second I would check the belt for the drum but I would think for sure that you would hear that it is loose
seth
My clothes are covered in lint
Hello Pam, Take the lint screen over to the sink and gently wash it in dish soap and water. Let it dry and try it. Sometimes the small holes in the lint screen plug up from using fabric softener and/or fabric softener sheets. It doesn't take much to restrict the airflow through the lint screen.
Feb 14, 2014 | Samsung DV330AE Dryer
Broken lint screen, what are the 2 wires attached to lint screen housing?
the red wires go to the sensor,this is used for the auto dry where it might say more or less,when the clothes spin they rub up against the sensor when the clothes start to dry it senses this and advances the timer until the clothes are dry and then the dryer will shut off automatically.go here to see the part
https://www.repairclinic.com/PartDetail/Moisture-Sensor/131845801/823088
Nov 20, 2017 | Frigidaire GLGQ332A Gas Dryer
F @ P DEGX2 lint trap problem
If you are collecting more on the outside of the house means the lint filter has a tear in it and the lint in being pulled through the tear and pushed out the exhaust. It sounds like you need a new filter but this isn't cheap. If you do it your self it will run about $70 if you get a repair man it will cost about $150.
Feb 25, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Why is lint collecting inside my Duet dryer? It is outside the drum and between the housing. The lint collector has little or no lint after drying. I have checked and cleaned the hose from the dryer to the...
take the lint filter out and put your hand in it,turn the dryer on,you should feel a stoung air flow sucking in,if not your still have a clogg somewhere
Feb 05, 2010 | Dryers
My dryer keeps burning my clothes
I recently solved this problem on my dryer by taking apart the lint collection area. Some dryers allow you to do this by removing a couple screws surrounding the lint screen holder. Others require some dis-assembly of the top and front panel.
Once you have access behind or below the lint screen, use your hands or a strong vacuum (shop-vac) to clean out any collected lint that has fallen below the collection screen and settled in the exhaust duct. I pulled out about 100 cubic inches (~1.6 liters) of collected lint, cat hair, and debris that was obstructing air flow.
Obstructed airflow can cause metal parts near the heating element to overheat and scorch clothing and is a serious fire hazard.
Jan 13, 2010 | Dryers
Our GE gas dryer is burning clothes that are fleece fabric or blankets. Any suggestions?
I recently solved this problem on my ELECTRIC dryer by taking apart the lint collection area. Some dryers allow you to do this by removing a couple screws surrounding the lint screen holder. Others require some dis-assembly of the top and front panel.
Obstructed airflow can cause metal parts near the electric heating element to overheat and scorch clothing and is a serious fire hazard. I expect similar problems can occur with gas dryers.
Dec 28, 2009 | GE DBL333GB Gas Dryer
Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
May 12, 2009 | Fisher and Paykel DEGX1 Electric Dryer
The drum is spinning, the heats working, not drying
Try washing both lint screens with soap and water and letting them dry.
Apr 04, 2009 | Asko T700 Electric Commercial Dryer
Cleaning lint
Your Roper dryer is made by Whirlpool, there is no reason to clean lint from around the heater, very little lint collects in that area. Every once in a while you can take the front off by removing 2 screws from under the lint screen, then pry up the top and there are 2 screws that hold the front on inside facing out. After removing the front you can vacuum inside below the drum.
Jan 18, 2009 | Roper REX4634KQ Electric Dryer
Lint screen is warped and does not collect very much lint
If the dryer is less than a year old the lint screen should be covered by warranty I would replace the lint screen to see if that helps.
Jan 06, 2009 | Kenmore 67082 Electric Dryer
Dryers Logo
81 people viewed this question
Top Dryers Experts
