Question about Whirlpool Dryers
My whirlpool Duet Dryer GEW9250PW0 keeps shutting off after a few minutes and displays an E2 message. What does that mean?
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Duet dryer error code
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Posted on Aug 05, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
Jahn27
  • 1554 Answers
SOURCE: E1 whirlpool duet electronic gas dryer error keeps
The fault code means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table below for the normal thermistor resistance values. Replace the thermistor if the measured resistance is not in the table.
Check the continuity of the wire harness if the thermistor resistance is good and make sure the connectors are fully inserted. Replace the harness if it is broken (no continuity). The problem lies in the electronic control board if no issue is found in the harness and the connections.
The thermistor is located on the blower housing and can be accessed through the toe panel. Shut off the gas supply and disconnect electrical power to the dryer. Remove the two hex-head screws from the bottom flange of the toe panel then pull the panel down and off the cabinet.
Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct.
Remove the wires from the terminals of the thermistor when measuring its resistance. Remove the two-hex-head screws securing it to the blower housing when replacing it and install the new one. Reassemble in reverse order of the disassembly steps.
Posted on Aug 11, 2010
Whirlpool Duet (GEW9250PW0) motor test
How did you decide to test the motor? What is the initial problem?
Jul 23, 2013 | Whirlpool Dryers
My dryer stops after 15 seconds and the code is E2, what does this mean?
E2 and fast shutdown is a shorted thermistor. The thermistor is mounted on the blower housing right next to the duct fusethemobilian_1226.jpg
Video:
Service manual and more info is HERE
Feb 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Code E1
E1 or E2 Thermistor Failure
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
Jan 12, 2010 | Whirlpool RBS275PD Electric Single Oven
My whirlpool dryer just beeps when you try to start it. The panel is lit up the door is shut, push start and it just beeps...any idea what the problem is
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control Locked light is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If holding doesn't unlock the feature, it is likely a faulty interface. I am having the same problem with my Whirlpool dryer and it is the interface, but it seems that a lot of people are able to correct the issue just by pressing the End of Cycle button for 3 minutes.
Here is a link to parts, numbers, and prices from Sears:
http://www.searspartsdirec t.com/partsdirect/getSubComp.pd?modelNumber=GGW9250PW1&productCategoryId=0151200&brandId=1198&modelName=RESIDENTIAL-DRYER&diagramPageId=00001&componentDescription=TOP%20AND%20CONSOLE%20PARTS&documentId=W0508037&blt=06
Jan 09, 2010 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool Duet Dryer. I keep getting an E2 code. What does that mean?
Not sure but you can go to Google and type in "E2 whirlpool duet dryer" and it should tell you what the code means
Jan 25, 2009 | Dryers
I HAVE A WHIRLPOOL DUET GAS DRYER MODEL NO. GGW9250PL0 THAT KEEPS BEEPING EVERY FEW SECONDS AND THE DIGITAL MINUTE DISPLAY IS ERRATICALLY CHANGING THE NUMBER OF MINUTES WHEN TRYING TO SELECT DRYER SETTING....
We had the same problem. Sometimes unplugging it for a few days, it would work when plugged back in. We replaced the user interface which is part #19 on the Whirlpool parts list, the front circuit board. The part alone was $160 at the cheapest place we found. http://www.appliancepartspros.com/
Dec 11, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer (5yrs old)
An E1 Code is a thermistor fault TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
157 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
