We have a bizhub c350, when it prints it looks like the toner is scratched as it goes thru machines before fuser. This happens on all types of paper. the lines are about 1/16 in wide and rough 1 inch apart. we thought it was a guide plate before fuser and replaced it as the fingers on it were approx. in line with the scratches (lines) did not help. Anyone have any ideas?
The problem us located in the image unit area. You can check the cleaning blade and the drum. If the lines is one of the cyan, magenta, yellow or black color, then check the drum and cleaning blade for respective color (ex. if the lines is black, check the black image unit).
I hope this tips to be usefull !
SOURCE: COF36 error on a Bizhub C350
Hi
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
SOURCE: put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
