Question about Epson Office Equipment & Supplies
Epson l120 won't print on thick paper, why? - Epson Office Equipment & Supplies
  • Epson Master
  • 1,083 Answers
Posted on Feb 12, 2019
mitpatterson
  • 74 Answers
SOURCE: thick paper wont print
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed0c16087.jpg
Posted on Oct 25, 2008
srinivas1515
  • 108 Answers
SOURCE: Thick paper won't print
check ur printer settings and try again if not soloves to and change the paper better to use thick paper
Posted on May 21, 2009
  • 15 Answers
SOURCE: Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Posted on Jun 01, 2009
SOURCE: Printing on thick paper (thick 3)
You can print thick 3 only from bypass tray.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
  • 1043 Answers
SOURCE: Can I use thick paper to print on Epson DX 8400?
There is a Paper Thickness lever on the left hand side of the front of the printer. If you go to the following website:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?infoType=Doc&oid=58606&prodoid=56291067
You can get the Product Information Guide, or the User's Guide. Both of these will describe which setting you should use for a wide variety of paper. For normal single sheets of paper the lever should be in the down or "L" position. If you are using envelopes the guide instructs that the lever should be in the up or "H" position. They give you a complete table with the appropriate settings to use depending on the thickness.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Posted on Feb 19, 2011
R320 printer won't print on thick photo paper anymore. Regular copy paper works fine. Are there rollers or sensors that I can get to so I can clean and check? Is there a fix for this problem?
  • Make sure that the paper meets paper specifications of the product.
  • Spray compressed in air.
  • If it is a non-Epson brand paper, try Epson paper
  • Make sure that settings are setup properly, Some Epson products have a Thick paper and envelopes or Thick paper to allow it accommodate thick media
Feb 14, 2013 | Epson STYLUS R230 InkJet Photo Printer
Can I use thick paper to print on Epson DX 8400? Is there any way to adjust the thickness of paper?Thank you.
Feb 19, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Epson R1800: printing 13x19" velvet paper. hand feeding into rear of printer. keeps saying eror, or paper jam or ... then finally just spits the paper through and out.
why print velvet paper? the problem is the velvet would be too thick and it would jam the print heads because when they run over the paper it would pull the velvet and it would get jammed i don`t think you should print velvet
May 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Epson 10,000 won't print on posterboard
Prints on 44" Wide paper up to 1.5mm thick
Does this help at all?
May 29, 2009 | Epson Stylus Pro 10000 InkJet Printer
May 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Black ink marks on prints from Epson R380!
Hello:
I have been having this problem all day today and believe I resolved it. The photo paper is thicker (I'm using the Ultra Premium Photo Paper by Epson). I have an Epson 1280 photo printer. I opened the lid and moved the lever to adjust for paper thickness, and voila––no more black ink tracks down the one side. Since photo paper is thicker, this may be your problem as well. Check your manual and see if there's an adjustment for things such as printing envelopes and change the setting. Hope this works for you! I wasted about 6 sheets of paper until I thought to adjust for paper thickness. Please let me know!
Susan
York, PA
smfree@comcast.net
Mar 26, 2009 | Epson Stylus R380 InkJet Photo Printer
Paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Mar 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
751 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
