Question about Garden
Scott's Lawnmower/after using all the gas in the carburator...
After using all the new gas in the carburator the engine dies. Rplaced with new gas and took carburator apart 3 times.
    Scholar:
  • 173 Answers
Check the fuel inlet, and make sure that the 'feed' is ok.
You might want to change/flush the fuel filter.
Have fun ;)
If problems still persist, you know where to come.
Posted on Aug 01, 2009
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
My lawnmower starts but does not stay on
If it starts and runs and then slowly dies, it is more than likely your carburator jet is stopped up.With it being blocked, it is starving for fuel. You will have to clean out the carburator and retest. Also check your engine compression.
Jan 17, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Lawnmower starts and dies... where is the main jet for the carb?
try cleaning the air filter, then a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season.
Aug 27, 2010 | Poulan "Poulan" Push Mower
I can't start my honda lawnmower, checked the oil, put new gas use choke,it gives litle sound but not enough to start
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jun 10, 2010 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
Makes extra oil, has died & won't start, rplaced o2 sensor started and ran for a bit, has now died again??
It can't make oil. It must be fuel or antifreeze mixing with the oil. Is it running really rich and flooding the engine out? That would explain gas in the oil. Or do you notice the antifreeze level going down?
May 15, 2010 | 1994 GMC Sierra
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18 hp briggs will run for a little while then die. Checked coil and new gas
It's possible that you have condensation built up in your carburator. Tiny droplets can deny gas to the cylinders. Since you put in new gas and I assume you are getting spark, drop the bowl on the carburator and check for this culprit. Could be a quick fix.
Hope this helps... Good luck!
Oct 04, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Murray 22'' 6.0 hp gas lawnmower engine dies right after start up.
SOUNDS LIKE YOU NEED A FULE FLUSH AND CARB KIT
Sep 27, 2009 | Garden
92 cadillac white smoke coming from carbuerator .....
white smoke is water, I would drain the tank and start fresh
Jul 09, 2009 | 1992 Cadillac DeVille
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
