Question about Amana ATB1832AR Top Freezer Refrigerator
Water leaks from line leading to ice dispenser
Leaks where the line connects to back of dispenser outside at top of refrig. line has no holes
  • 308 Answers
Check to make sure your fitting is tight, and if it is, and is still leaking, turn the water off, disconnect the fitting and make sure the compression sleeve is seated correctly. Note that if the sleeve doesn't look correct, then you will need to cut the line and replace the sleeve. Hope this helps.
Posted on Aug 01, 2009
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water leaking from bottom of fridge. Hissing noises coming from inside. Trying to figure out how to disconnect water
There is usually a water cut off , behind the refrig , mounted on the wall , or , a cut off under the sink , connected to the cold water line ( with a small cut off valve ) .
The hissing noise , is usually associated with a hole or cracked water line . You can also try removing the ware filter , to see if the noise stops .
Would need more info , to have an idea where the water line is defective .
Nov 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a leak from the back of the refrig where the white water supply line goes into the yellow bracket. I can not get the house back into the yellow clamp.
That line , usually pops out when the fill tube is clogged with ice , due to a seeping water valve . If 2 screws hold this bracket , remove them and pull the fill tube out and defrost and reinstall . Use wd40 at an angle, to keep from getting into the line , to slip the line back into the bracket and replace the water valve ( the piece connected to the refrig where the wall water line connects to ) .
Oct 21, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Leaks water in the refrigerator down the back under
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
GSS25LGMF WW Will not dispense ICE or Water, lights are on
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Water leak where hose meets refrigerator connector
I had a similar problem several years ago with water leaking on the floor at behind the fridge. Turned out to be the gasket at a connection the same size as a garden hose at the water valve, so I used a garden hose washer and that did the trick. That was on a Whirlpool vintage about 1990. Can't say what the model was.
Mar 01, 2008 | Refrigerators
Amana ATB1832AR Top Freezer Refrigerator Logo
104 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
