Question about LG Refrigerators
LG Refrigerator has no cold air for fridge but freezer works fine
I have approx four old LG fridge. The freezer had a little frost because I left the door open slightly (by accident).
A few days later the freezer works the same as usual but for the last day the fridge hasn't worked. All food has gone to waste... though I think a tiny little air is there but not cold cold cold.
I have tried turning it off and removing all frost (well believe so) and cooling the compressor as it was steamy hot . Still the fridge part does not work. There is no water in the drip tray are the back like normal. In the past I think the fridge has overheated and my safety power cut out power to the fridge... I just let it sit with fan over it too cool and it worked again... this was when it was hot. In winter now so I cooled the compressor this time with a damp tea towel.
Initially I thought in may need to be regased but my freezer is working fine.
LG NR62LAEG
    Champion:
  • 363 Answers
Sounds like the freezer fan(FF)is wearing out, This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. This repair costs parts and labor around $300.00
Posted on Aug 05, 2009
LG LSC26905TT refrigerator not freezing. Everything is melting in the freezer and fridge.. Lights are on, but no cold air is coming.
Remove all items from the fridge and keep open the fridge doors for atleast 2 days and that will remove all the frosted ice on the evaporator(which can't be seen) and shall work fine after two days.
Feb 26, 2014 | LG LSC26905TT Side by Side Refrigerator
My Maytag Plus refrigerator does not work, lack of frost, cold. The freezer side is working fine.
Need to see if the damper is open inside the fridge.  This the vent in to top left hand corner.  If it is not open then the damper needs to be replaced.  If it is open then one of the return vents (lower part of fridge) is blocked/plugged.  Let me know what you find.
Oct 21, 2007 | Maytag MSD2756G Side by Side Refrigerator
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
May 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge and freezer not staying cold - Got home last night and my whirlpool (frost free) fridge/freezer was switched on (power running to it - light etc working) but was not chilling properly. Everything in...
This can happen if the fan motor in the freezer compartment is bad. Causes the freezer section to freeze up and you will not get air circulating, so no cooling. Check the fanmotor
Nov 06, 2009 | Cars & Trucks
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
GE side by side Refrigerator approx. 8 years old. Fridge side barely cold.
With your fridge, does the light go out when you shut the refrigerator door?
That could be your issue, that light running inside will create Alot of heat.
Also check to see if there is air circulating from the freezer to the fridge side through the damper. The damper is on the Fridge side left wall up towards the top. That is where the cold air gets to the fridge side. If that damper doesn't open that will also cause your problem, Let me know how you make out.
Bill
May 14, 2008 | Refrigerators
Refrigerators Logo
582 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
