My Gateway 4540GZ boots to black screen w/cursor...help
My Gateway 4540GZ isn't booting correctly. It ends at a black screen with blinking cursor. HELP
  • Jorge Majano May 11, 2010
    do you have the system restore disk that came with the computer?
  • 104 Answers
Remove the and test it H.D.D or change the RAM ,
Posted on Aug 01, 2009
How do I replace the f1 fuse in my gateway 7326
Will it boot? Fan spin? LED's blink? Sound? Try connecting to a external monitor, does it show desktop? The screen is all black, no cursor at top left? No "ghost Image" in the screen when viewed in a bright light? I would look at the inverter board, backlighting, ribbon cable in the rear of the monitor, the LCD screen, your laptop has some miles on it. Not sure about a fuse on a laptop motherboard, don't see that often. Take a look at this may help you troubleshoot: http://www.youtube.com/watch?v=2Yi6GNFcP3w
ALSO Gateway Support may help: https://support.gateway.com/s/Mobile/Gateway/7305GZ/4694nv.shtml
Feb 08, 2013 | Gateway Computers & Internet
ASUS EeePC 900A- black screen blinking cursor
The hard drive has issues, or the window files are corrupt. I suggest a computer repair store to retrieve files and test hardware.
Aug 05, 2012 | ASUS Eee PC 900 Notebook
My gateway 4540GZ won't boot up when I turn it on
Disable other bios setup and enable only the hard-disk.The procedure is these:put on your machine for the first time immediately press (F2) button.if it refuse to display off your machine and restart Then immediately press (F9). when it display the setup locate and select boot menu it will display all the booting function such as: CD/DVD RW, HARDDISK,ADAPTER AND SO ON just select each one it will show two options:ENABLE/DISABLE. you just select disable for others except HARDDISK should be ENABLE.finally,close it and apply save& exit.restart your computer it will definitely boot up.
Nov 24, 2011 | Gateway Computers & Internet
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
Hi, i have an eee laptop!! and some of the keyboards are not working!!! is there any key that can subtitute the fn key?
Hi wincel03_dar ,
I see that you are having issue booting into your Windows, I can help you with your concern. You mentioned that you get a black screen with a blinking cursor on the upper left, this means that either your Hard drive is not detected by the motherboard or Windows is not found, see steps below.
  • Turn your Laptop ON then keep on tapping F8, you should see a screen windows advance options menu, hight light and select Last Known Boot Configuration then press Enter
  • The Laptop will restart, see if it will boot into Windosws
  • From shut down turn your Laptop on again then keep on tapping F12 this will give you a Boot Menu Screen.
  • Once you have the boot menu screen Select ATA HDD it should be the first on the list if it is not located then the Hard drive isn't really detected.
  • After selecting the ATA HDD press Enter this should boot into the Hard drive, if still it does not boot and it gives you the same black screen with a blinking cursor then you can try reseating your Hard drive from the system.
  • Reseating meaning Remove it then wait a couple of seconds then put it back in properly then try turning the machine on again.
If still he issue is the same and you get a Blinking Cursor then it can be two thing either you Hard drive has gone bad or your motherboard could not detect your Hard drive.
To find out you can try and use your Hard drive on a different Laptop if the data from your Hard drive works on a different Laptop then your Hard drive is OK and that the problem is your Motherboard not be able to detect your Hard drive and need replacing.
I ope that this will be able to help you with your concern,
Thank you choosing Fixya.
mvincentc
Apr 18, 2011 | ASUS Eee 4G Notebook
Gateway desktop wont boot up into OS XP just blinks with cursor on black screen
try this strt the pc when you see setup on screen press F8 key a few times then you will see options like safe mode and safe mode with networking and you will see an option to boot from last known good configuration use keyboard arrows to select this option your pc will reboot if this doesnt sort it the repeat these steps and on the screen select safe mode and hit enter key or return key let the files load on the screen when th pc goes into safe mode the screen will look different clik on strt then select alll programmes then select accessories then select system tools then select system restore ....select a date when your pc was last working correctly and clik next let the computer do its work when it restarts it should be working correctly (NOTE) any progrmms you downloaded from the date you selected will be eresed but not your documents or downloads like movies ...hope this helps
Dec 19, 2010 | Gateway GT4016 Desktop PC
THE MONITOR ON MY ONE PIECE GATEWAY PC IS BLACK BUT THERE IS POWER TO THE COMPUTER. TRIED PLUGGING IN AN EXTERNAL MONITOR BUT HOW DO I GET IT TO WORK WITH THE COMPUTER?
Addressing this as a Gateway 4540GZ PC Notebook. If it is a different computer please state in a Comment.
Gateway Support > Gateway 4540GZ main support page,
http://support.gateway.com/s/Mobile/Gateway/4536GZ/4356nv.shtml
User Guides > Click on > 8510221-Gateway Notebook User Guide
Page 31 - System Key Combinations
Press the Fn key, and the F4 key to toggle over to an external monitor.
(External monitor plugged into the VGA port on the back of the laptop, and turned on,
VGA port,
http://en.wikipedia.org/wiki/VGA_connector
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
Nov 02, 2010 | Gateway 4540GZ Notebook
BLACK SCREEN WITH CURSOR NOW WITH A BLINKING LINE
Sounds liek your hard drive has failed, search ebay for this model of laptop with hardrive at end of yoru search, not 100 percent sure but im nearly 90 percent sure its hard drive failure.
Dec 03, 2009 | Gateway P-6313 Notebook
Computer displays black screen with blinking cursor
Its seems its not booting correctly. Just Insert Windows CD and fix the windows. Another solution is to press (I think) F1 or F11 or F12 (depending on the model) when booting the machine. It will take you to recovery mode. Use it to restore the boot section ONLY.
Mar 06, 2009 | Sony VAIO VGN-CR220E/P Notebook
Windows vista won't start
Open your system and fix any cable inside the system, maybe gor a loss connection. i guess that hard drive not detected. so fix it. please tell me what happen next i will surely give you more solution in it.
do not rate me if this not solve the problem.
at last remove and clean the memory fit it exactly to the slot.
best regards,melnavz
Apr 09, 2008 | Gateway GT4022 PC Desktop
Computers & Internet Logo
648 people viewed this question
David Payne
David Payne
