Question about Husqvarna Zero Turn Mower Z5426
Husqvarna Z6127 won't start after running 30 minutes.
Sounds like starter motor is spinnning but engine does not appear to roll over at all.
    Problem Solver:
  • 9 Answers
If the starter motor is spinning, the problem is probably the starter motor solenoid. It is basicly an electric piston mounted on the starter that engages the starter motor pinion gear to the flywheel.
Posted on Jul 31, 2009
Tiller won t start
The fact that it started for any length of time, tells you the engine functions. The engine is STARVED of fuel mixture. Either the inside fuel line is clogged and needs to be blown out or the carbonator adjustment is incorrect. Check to see that the spark plug GAP is proper and when placed back into the engine it is hand tight with the spark plug wire formly in place.
Mar 01, 2014 | Husqvarna Garden
Engine stalled and engine not starting
Have you fuel? Filter may be blocked or ignition coil breaking down?
Nov 02, 2017 | 2005 Ford Escape
Engine won't start, starter makes rattling sound
sounds like the battery disharged. If the key was on along with the lights than 20 minutes would be enough to drain the battery. Try a jump start. it should get you going. I would have the battery tested after driving for at least an hour at highway speeds just to make sure it is good.
Apr 30, 2013 | 2010 Ford Fusion 2.5
2006 Ford Expedition will not start this morning, battery checks 12 volts, will not do anything when turn key to start position
You can jump starter relay to see if starter will crank the engine. Pull the starter relay, use jumper wire between terminals 30 and 87, terminal 30 is hot all the time and there is a fuse, the starter motor should crank the engine. If you try that make sure tranny is in park or neutral and parking brake is set. Two voltage circuits at starter motor, one is hot all the time. The other goes hot when relay is energized. The starter motor grounds through engine block. Battery positive and negative connections are important.
Nov 18, 2017 | 2006 Ford Expedition
Disconnected battery and now won't start
Won't start as in no rotation of the starter motor and no clicking sound? Or starter turns slowly with the engine? Or the starter and engines turns normally but will not start? Or starter turns normally but engine will not turn?
Oct 15, 2012 | 2004 Jeep Grand Cherokee
Why won't it crank over?
Sounds like the starter. The faint click would be the starter solenoid, trying to operate starter. Have it tested.
May 05, 2012 | Cars & Trucks
Starter clicks butengine won't turn over on 99 Buick Park Avenue. Battery is fine and starter solonoid is clicking but not engageing and engine not rolling over?
sounds like a bad starter motor, autozone will test it free out of car.
it is a royal pain to get the starter out so pay close attention so it will be easier going back in.
Oct 07, 2011 | 1999 Buick Park Avenue
I started the engine twice after the engine was already running...I assume I might have flooded the engine with fuel? But when I turned off the engine the car didn't start again and the Anti-Lock Light...
If the engine is running when you try to use the starter, it won't flood the engine, it is already running. What happens is the starter gear tries to lock into the flywheel and this causes the starter to spin faster then it is supposed to. It is likely you damaged the starter and it needs replaced. You can remove it and have Auto Zone test it for free.
Aug 11, 2011 | 2001 Mitsubishi Galant
Motor rolls over slowly like drained battery or bad starter
Has timeing been checked and how does vehicle run
Oct 02, 2009 | 1996 Chevrolet Blazer
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
Aug 20, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Husqvarna Zero Turn Mower Z5426 Logo
555 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
