Question about Maytag Washing Machines
Maytag centennial washer won't drain and spin on any cycle but WILL on drain and spin
Maytag model MVWC35
    Habit-Forming:
    New Friend:
  • 26 Answers
I think if it isn't draining on one cycle but is on another. I would try to narrow it down to the Main Control Board. If the pump was bad, it wouldn't drain at all, just spin on all cycles. A local appliance repair should have an replacement. Or order online.
maytag centennial washer won't drain and spin on a - s-l225-w5q2f53pd3i2dcygmzzrygw1-4-2.jpg
Posted on Apr 05, 2018
  • 784 Answers
SOURCE: Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Posted on Aug 09, 2009
SOURCE: Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Posted on Feb 27, 2010
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
richroth
  • 9472 Answers
SOURCE: Washer immediately goes into wash cycle when
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Jan 26, 2011
Jahn27
  • 1554 Answers
SOURCE: Maytag Centennial Washer model MVWC6ESWW1
It sounds like this is a clutch and brake assembly problem. The clutch spring must provide the necessary pressure for the lining to turn with the hub and the clutch tab to push the brake cam driver and release the brake. The clutch spring of your washer must be weak or the clutch lining is worn causing it to slide and not release the brake. This prevents the tab that holds the clutch spring to force the brake cam driver, release the brake, and allow the basket to spin particularly when the machine is under load. This is manifested in the spinning of the drum when the machine is empty. The clutch and brake assemblies are located just below the tub and the excessive heat resulted from the friction between the clutch lining and the clutch hub.
Remove the thrust washer from the agitator shaft then remove the clutch and brake assembly from the top of the gearcase by removing the retaining clip using a screwdriver. Unsnap the clip and the clutch retaining ring the slide the clutch off the agitator shaft. Make sure to retain the washer located under the clutch.
Install the new clutch assembly on top of the gearcase then insert the clutch band and hold it in place. Using a pair of needle-nose pliers, place the end caps on the clutch spring and compress to insert into the open end of the band. Release the tension on the spring and the band will stay in place the reinsert the retaining clip on top of the clutch.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 30, 2011
Wash cycle will agitate 3 spins then nothing for a few minutes then 3 more and nothing again and repeat over and over
you may want to put it through a diagnostics cycle and check for error codes... Maytag Centennial Washer Repair Guide
The tub sensor can cause the washer to act strangely like that. Also there are two mechanical styles of washer branded Maytag Centennial. The model number would help to know we are talking about the one I think we are talking about.
Hope that helps!
May 27, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Specs for model#MVWC400XW0 Maytag Centennial Washer
It definitely could be a clogged or bad pump. However, it's always a good idea to check for error codes before replacing a part...Especially expensive ones...
http://applianceassistant.com/Washer-Repair/Maytag-Centennial/Maytag-Centennial-Washer-Error-Fault-Codes.php
Hope it helps! Good luck!
Mar 02, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag centennial washer - not draining on some settings
Check outlet hose for kinks or restrictions. Make sure the outlet hose is free to expel water at full volume. Make sure the outlet hose is not mounted to high. Check pump impellor has all it's vanes intact. Check for coins in all hoses & pump.
Dec 21, 2013 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing Machines Logo
1,767 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
