Question about RCA Televison & Video
I have an RCA 38-inch HDTV (F38310). While watching, it began scanning through all the options (vcr1, vcr2, directv, etc.). The volume bar also popped up and the sound was turned down. I couldn't control the sound or anything else with the remote (I changed batteries). Then couldn't turn off tv either with the remote or the TV on/off button. Uplugged TV and then couldn't turn it on. Uplugged it again and let it sit for a day. Turned it back on, and it came on but it started doing the same thing as described above. I watched it for about 5 minutes...if that long...before it started. Can't change channels or anything.
  • 114 Answers
Apparently this is a common fault with this model, contact the retailerfor a refund or repair. pitiful power supply, poor-quality electronics, etc.
Posted on Jul 31, 2009
I need to know how to program an old rca CRK76AD1 surround remote that works a tv, vcr1, vcr2, dvd, am/fm, cd, tape,sat-cab
1. Turn on the component to be programmed.
2. While keeping the corresponding Source Button pressed (like TV, VCR1, VCR2, DVD, etc.), enter the 4 digit code for the device using the number buttons.
3. Release the component button, then press ON-OFF to see if the component will be turned off.
4. If this does not work, repeat steps 2 & 3 by trying to use the next code (if available) listed for the brand of your component until the component responds to the remote command.
Jan 05, 2010 | RCA Televison & Video
Moving abroad
you would need a power converter Europes power runs on 50hz power were the u.s. uses 60hz if you plug your tv in in Europe you will damage it without a converter
Apr 27, 2009 | Televison & Video
SETUP RCA F38310 TO DISH NETWORK
using your Dish Network box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. Or you can connect your Sattelite to the antenna A or B input jack on the back of the set and set the tv input to antenna
Apr 14, 2009 | RCA F38310 38" TV
Other inputs not working on rear projection toshiba
check for progressive scan and interlaced setting also verify if you have component hook up that it auto maticall chooses your resolution because if your tv is waiting for 1080i and you send 1080p it will not always work and if it expects 1080i and you send it 480i(s-video or rca connection) it may not automatically flip
Apr 14, 2009 | Toshiba 42H81 42" Rear Projection...
Channels and inputs change by themselves
sometimes unplugging it from the wall for a few minutes or even overnight can fix weird issues like this.
also, there is a small chance that a new channel scan thru the menu system might refresh the channel memory and clear it up.
this series of TV's are prone to a lot of problems tho, so it will likely soon be time to start shopping around.
Feb 11, 2009 | RCA F38310 38" TV
Setting the component video settings
If I tell you how I fixed it, send me $9.99.
Dec 17, 2008 | JVC RX-8040B Receiver
I want to duplicate a vhs tape....how do i hook up 2 vcr's and the tv to do so?
vcr1 plays the tape
vcr2 does the recording
connect vcr1 video/audio output to vcr2 audio/video input to audio/video output to tv audio/video input
May 27, 2008 | Televison & Video
More info on my RCA F38310 38" TV
Thanks for the reply.
Go to this site and browse through their stock of parts for this TV model. You can give them a call as well if you do not see what you are looking for.
Good Luck.
Apr 13, 2008 | RCA F38310 38" TV
How to set up to copying a video tape.
This is a snap, as long as you have a second VCR if not you can't do it.
1. Hook the out put line(s) from VCR1 to the input line(s) on VCR2.
2. Put recorded tape into VCR1 and press play.
3. Set VCR2 to the channel that VCR1 is playing on, it's usually 3 or 4.
4. rewind the recorded tape and put the blank into VCR2.
5. Press record on VCR 2 and play on VCR1.
if you want an exact copy stop here. . . or
6. pause VCR2 when ever something comes up you don't want to record, ie a commercial if you'r re-recording a movie from TV. be for warned though each time you re-record an analog recording, like a VHS tape, the audio and vido tracks get further and further apart. After about the second or third time you re-record a tape you'll hear something before you see it, or vice-versa. I hope this helps you out.
Dec 24, 2007 | Emerson EWD2202 DVD Player/VCR
Bad diode.
It seems that the number provided "CR14710" is the number near the part on the board. Are you sure this is the part number or rather, is it the part's schematic reference? I interpret "CR14710" as Control Rectifier 14710 that can be found on a schematic. I say this because you also said "a badly burned diode" and usually the part number becomes illegible from this.
Dec 11, 2007 | RCA F38310 38" TV
Televison & Video Logo
87 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
