Question about Eureka Whirlwind 4496 Bagless Upright Cyclonic Vacuum
When I use the hose, it makes a hissing sound that wasn't being made before. The suction power seems to be not as strong.
  • 40 Answers
Either you have a hole in your hose or there is a knob on the top of the hand that is open.
Posted on Jul 31, 2009
Dyson DC14 hose won't extend and floor unit lost suction
Sounds like the exhaust side is clogged. Remember a vacuum pulls air into the cavity, but for it to work properly it also has to be able to exhaust the same amount of air it takes in. If the exhaust is blocked it will continue to suck air inside and collapse on itself, which is why your hoses are getting shorter and harder to move. Check the exhaust system for any blockages, perhaps the hole you taped was the exhaust.
Mar 15, 2015 | Dyson Vacuums
Lg 300B no suction through hose
If you have a loss of suction overall, that generally means one of two things, either you have a clog somewhere near the motor or the motor is fried and will never turn fast enough to make proper vac.
Nov 09, 2013 | LG LUV300B Bagless Upright Vacuum
Vacuum has lost suction and is making a hissing noise
I had the same problem with my Kompressor.Initially I had cleaned all three removable filters.There is two in the canister that can be washed with dish soap. The HEPA filter is located in a compartment on the lower front side of the vacuum.This HEPA filter should not be washed.I found that tapping it inside a trash can dislodged alot of dust from it. After cleaning all the filters and canister I was having the same hissing noise coming from a small hole near the bottom of the vacuum. Next I removed a hose fitting on the lower back of the vacuum and that is where I found a very large amount of debris clogging up the hose. I used a metal coat
Nov 11, 2011 | LG Kompressor Upright Vertical Cyclone...
My dyson vacuum cleaner doesn't seem to have the same suction power it used to. I have cleaned out the canister and have taken apart the vacuum head (for cleaning carpets) and it doesn't seem to be...
Hello, this is Ava with Think Crucial.
Most of the time the reason why the vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this.
You can purchase a wide variety of high-quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 08, 2011 | Vacuums
I just bought a used Dyson DC07. Works good but
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Dyson Customer Service
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Nilfisk A300 Suction problem
Mate - don't know if this will help - I had the same symptoms - saw your question through google - no answers, then I moved the red slider button on the top of the vacuum and hey presto! It has adjustable power. Man I felt like an idiot!
Jan 30, 2010 | Vacuums
My hoover has no suction at the nozzle, though it has strong suction at the hose. This problem started after I replaced the vacuum bag for the first time.
there is a blockage behind the roller brush remove the roller plate and the roller and check the inlet hose for a blockage also remove the bag and chek the inlet to the bag for some type of obstruction. Don the Vacuum Doctor Alb, N.M.
Nov 01, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Is there a second filter
You have not posted a brand, however central vacs with an internal hanging `self cleaning ` filter seldom contain another filter with the exception of Eureka or Kenmore which may have a secondary optional paper filter installed. Check the bucket and the gasket first. Eureka and Kenmore made by Eureka are prone to a defective gasket which disintegrates with wear. The bucket should sit snug on any unit with no play.
To test for proper suction check at the vac intake itself. If the suction is strong here and weak elsewhere your problem will be either a clogged vac line, a leak in a pipe or an inlet door sagging open, last of all a clogged or partly clogged hose.
Check your hose by dropping a coin through the handle and shaking it down to the other end. If a coin makes it through your hose is clear.
You can test each inlet with a numbered tissue and your hose. Mark one for each inlet and check the tank to see what made it through. If any fail to make it through, go to that inlet with another vac and draw the blockage backwards out the inlet. Then retest
Also listen for a hiss at each inlet with the hose plugged in elsewhere. The hiss indicates a leak behind the inlet in the wall. Check for worn seals or misaligned o rings in the backing plate where the inlet connects.
Last of all inspect the pie for possible cracks from impact . If you listen closely you will hear an audible echo along the pipe path (even within the wall) if a connection has separated or a pipe is damaged.
Please post back with what you find or if you need more help.
Oct 13, 2009 | Vacuums
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Panasonic Stow'n'Go, model MC-V5481
If you turn the vacuum over, you will see a hose by the brushroll. I think your problem is that it's stopped up right there. Take off the brushroll and make sure that the hose isn't stopped up. The port at the back that makes a hissing sound is to indicate that it's stopped up somewhere. Also, when you replace your attachment hose back onto the machine, does the motor change sound?? That's also another indication that your machine is stopped up. Don't lose hope for the Panasonic, they're great machines. If you still need help, you may call us at 1-866-509-1952. Thanks.
Jul 10, 2007 | Panasonic MC-V7600 Bagless Upright...
Eureka Whirlwind 4496 Bagless Upright Cyclonic Vacuum Logo
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
