Question about Refrigerators
Freezer not freezing/ fridge not cooling
I realized the freezer was "out" this morning and moved everything. NOW I realize although the light is on in the frig and I hear "running", it's not cooling!
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Jul 31, 2009
Frig freezer wont get cold enough after move . 35 degress then back up to 45 . cleaned everything good . coils everything . worked fine till moved . waited 24 hours after move to plugg in . help
Hi Kim, Before you check out the link below, Read about your refrigerator not cooling?Is your older or newer model refrigerator plugged in, getting power, the lights are on inside but the fridge will not cool and the freezer won't freeze? If your refrigerator or freezer has suddenly stopped cooling and the freezer won't freeze, we have multiple solutions for you.If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor is overheating or not getting proper power and will not start. The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
Refrigerator Is Not Cooling What To Check And How To Fix
Apr 03, 2016 | Refrigerators
My maytag french bottom freezer drawer fridge has stopped working.model MFI2568AES I found out that the door was cracked open for about a week and the problem worsened over time .... I have since cleaned...
Not exactly sure whats going on based on your description. But let me tell you what I had to deal with:
Same situation where some fool left the drawer open, it caused the railings inside the drawer to freeze. I applied heat with a blow dryer to thaw it and had to realign it.
I've also realized that the freezer unit is what supplied cooling to the rest of the refrigerator (through forced air) and noticed that it works the same way with all the fridges ive delt with (maybe around 15 or so). So it doesn't make sense, if the freezer isn't cooling then the fridge shouldn't be either being that it uses the same source and it passes through the freezer first.
That said, I wonder if the fridge compartment is cooling?
Do you hear the compressor running?
Sep 20, 2014 | Refrigerators
Front panel, temp control, water, ice etc not working.
Can you explain more about the panel?Email me through this website at "skyethespy@att.net" no quotations
Mar 09, 2014 | GE GSS25IFR Side by Side Refrigerator
Water under fridge sometimes ice
Defrost unit and work everything loose. Wipe off all water and let it sit over night. Plug in next morning and allow 24 hours for temps to be right.
Sep 09, 2017 | Whirlpool GX5FHTXVA Bottom Freezer French...
Not cold enough all of the sudden
My refrigerator is running but not cool,the freezer side is about like the fridge side!
Dec 16, 2009 | Frigidaire Refrigerators
42" SxS Viking Not making ice
You may have to unplug the the unit and thaw it out with a hair drier,and get everything dry.Then close it up and set the temp,and plug it in.It will take a while before it will start producing ice again normally.If I can help,let me know.
Jul 19, 2009 | Viking 42 in Built In Professional...
Roper Freezer Stopped Freezing
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Jul 02, 2009 | Refrigerators
Fridge warm, freezer fridge temp
The adaptive derost control has gone bad a very common issue. It will work a couple of weeks before its back to its frosting over. It just plugs in but to get to it you must remove the controls at top of frigde section in the back right corner held in by two scewrs.
Mar 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
